81 caddy running smoother
[img:470b]http://forum.georgiadubs.com/
[/img]Truck has been running bad ...ie.... would not run over 60 and rough idle / hard to start..... added NEW warm up regulator & a used air valve ........and Wade Carter found that I had a vacume leak --hose from intake to the brake booster........... SMOOTH IDLE & BRAKES TO BOOT......THANKS WADE
bulldawgdude- Dub Nut
- Number of posts : 269
Registration date : 2011-03-30
water cooled worked on
( North of MACON GA ) if you need you water cooled worked on ... call Wade Carter..(478) 476-8813............. good work @ a good $ rate..
» my 81 caddy
» Sightings: Kinda like UFOs only for VWs instead.
» bulldawg in the caddy
» My 81 caddyz in Juliette GA
