Transaxle Problem
Transaxle Problem
My transmission needs work, or to be replaced. Friday it began stuttering as I let the clutch out, then finally the clutch pedal went to the floor as I pushed it and made a sound that was like something dragging on the pavement. No clutch. Looked under the car and nothing was dragging. The lever that the clutch cable goes to would not move so I'm guessing it is the throw out bearing since several people suggested that.
Prior to this, and probably unrelated, it had the tendancy to pop out of 4th gear.
I'm thinking that I just need to replace it with a used or rebuilt transaxle. Tim's has "good" used ones for $250 with a 30 day warranty, I found another one for $125, no warranty and I can't find anyone locally who rebuilds, which is what I would prefer.
I'm leaning toward the used one from Tim's.
Any other suggestions, or does anyone know of someone locally who can rebuild one?
Help me out guys, I'm drivin a freakin Nissan until this gets fixed.
Thanks
Thanks
VW12step- Dub Nut
- Number of posts : 499
Re: Transaxle Problem
Tim's seems like a safe bet. If it turns out to be a bad unit, he'll surely have another to replace it.
Gordon, have ya pulled the engine yet to see what has happened inside the bell housing? If ya want to go new Lindy has them no core required for $550 12mth, 12k, warranty. That's a swing axle unit an IRS could be more or less.
Going to do the autopsy tomorrow.
VW12step- Dub Nut
dude that sux.mine was popin outta 4th gear too.an when i wud take off from a stopin point it would shake the entire car.so i guess it went out...lol..i had to put a new one in
i just talked to him a few minutes ago, and it turned out his cross shaft took a crap, and i think he said it destroyed his TO bearing as well. he said he's gonna try to ge tthe motor back in tonite.
