Redneck Tire mounting
+7
Tybomb
11 posters
https://www.youtube.com/watch?v=7owrxqMFSy8
Anybody else ever tried this? I did it yesterday for a wheelbarrow tire. It was kinda scary but it worked just fine.
Re: Redneck Tire mounting
peregrine67 wrote:https://www.youtube.com/watch?v=7owrxqMFSy8
Offroaders have been using that trick for a while, you can tell by their lack of facial and arm hair
Yeah that's where I first saw it. A friend on mine knocked his tire off the rim in Moab about 30 miles from the nearest paved road.
Plus, those guys run so little air to get traction, it's easy to break the bead.
Thats how I had to mount these... granted, i did use a proper tire machine instead of prybars
Cambur- Complete Dub Addict
- Number of posts : 910
I've done that a few time and it's scary as hell. You have to be careful with the amount of ether you use.
Yeah I'll second that. I used about 1/2 second spray of ether on a wheelbarrow tire and it was plenty to get the job done.bakertim2 wrote:I've done that a few time and it's scary as hell. You have to be careful with the amount of ether you use.
That's why certified police officers wear specialized suits and breathing equipment when they have to search a meth lab house!!!!! Ether too explosive & dangerous!!
Remember the flash point on ether is so much lower than gas. You can breath on it and it will go off.
Hate to see your Dub go up in flames.
TOO DANGEROUS!!
TOO DANGEROUS!!
naa, it burns to quickly to do any real damage. tho obviously if you use too much you can blow up a tire (litterally blow up, in pieces, in your face). start with a little and use progressively more, till it works. done it on scar tires, and some trailer tires, worked well. i like to pull the valve stems out tho, before i do it, cuz if your not quick enough to fill the tire with air, as the heated air cools, it sucks the tire back off the rim.
Can't say anymore, I have seen what ether can do to a human body.
Caviat emptor - buyer beware!!
really? u mean because of the heat, or some kind of chemical reaction? never heard that before. scary. when i light a tire u usually use a rag or something on fire on the end of a stick. i'm always at a distance when i do the actuall lighting, lol.
a ratchet strap also works well, is alot safer than ether just my .02
runabout199- Dub Nut
- Number of posts : 114
Registration date : 2012-01-29
I have done it quite a few times over the years. I think its fun and exciting,does that make me a redneck
Knumb Knucks- Out of Control Dubber
- Number of posts : 1768
Hell, one of the tires currently on my bus was mounted this way...........
taint no big deal...........
He said taintDiggerD wrote:Hell, one of the tires currently on my bus was mounted this way...........
Allways worked for me too. Easy Peesy.
» '72 Bay Window Cot mounting Clip Maesurements
» what tire size?
» Max tire size
» tire pressure on 145/65/15
» tire clearance
» what tire size?
» Max tire size
» tire clearance
