'72 Bay Window Cot mounting Clip Maesurements
'72 Bay Window Cot mounting Clip Maesurements Empty '72 Bay Window Cot mounting Clip Maesurements
Post by rpm750 on Sun Dec 16, 2012 10:18 am
I need some one to measure how high the bottom screw is from a fixed spot for the front child's cot. I need the front measurement over the dash and the rear over the seat back pedestal. You only need to measure one side I will use the same measurement on the other side.
This cot came out of a '72 so I need this measurement from a '72. I did a search on the samba and VW changed the lengths of the rods a couple of times and if the rod was shorter the mounting spot was raised to accommodate the shorter rods. I guess I could hold it up and see where the rod length and the brackets work the beast and make sure the cot is level. A measurement would be nice to make sure I'm in the ball park before drilling holes in the pillars.
Thanks in advance.
'72 Bay Window Cot mounting Clip Maesurements Empty Re: '72 Bay Window Cot mounting Clip Maesurements
Post by type4revolution on Sun Dec 16, 2012 10:47 am
Call me I have a 72 bus with infant cot. you can give me a call today andill give you any dim you need 9123086970
Number of posts : 907
