Mud Flap install
Mud Flap install
Sounds dumb, but... How do you install mud flaps on a 1970 Beetle? I have the brackets, but can't seem to place them correctly. Do I need to drill extra holes?
jshmnghm- Dub Nut
- Number of posts : 311
Re: Mud Flap install
Or just show me pics of how yours are mounted.
jshmnghm- Dub Nut
Your brackets are most likely drilled for the early style bumper bracket hole pattern. I don't know if late brackets are available anywhere? You could either twist your brackets to make the flap look level, or make your own.
Good luck!
Good luck!
Yeah, It looks like I may be able to drill a couple holes and twist the brackets some, should work.
jshmnghm- Dub Nut
dude all you gotta do is hold the brackets to the car where that bolt to. and mark where you need to drill new wholes.then drill them am mount..lol..a friend of mine had the same problem last week but i mounted them for him. it isnt hard to do
» 1700 thermostat/cooling flap help
» Windshield Install Help
» windshield install
» What is required to install gauges?
» Third brake light install
