1700 thermostat/cooling flap help
I have a 72 bus with a 1700. I have never needed to look inside the cooling ducts until now when I replaced the oil cooler. My question is should I leave the thermostat flaps like they are and have been for years (driver flap down and pass up) or should I wire it open? It looks like the air has not been passing over the cooler at all really. I could maybe rig up something to allow me to move it manually. Thanks in advance
Muffler Bearing- Dub Crazy
- Number of posts : 731
Re: 1700 thermostat/cooling flap help
Put it in its original configuration by the book with thermostat
Do you have a thermostat for sale?
I'd have to check is that all your missing
Muffler Bearing wrote:(driver flap down and pass up)
From your description, it sounds like you have them open already. The way they work isn't intuitive at all. Driver flap goes down to direct more air over the cooler and the pass goes up to send more to the cylinders.
Greg- Dub Nut
- Number of posts : 118
I have the bracket,the wire and nut. If i have looked correctly I believe th flaps are in the warm up position until the thermostat heats up then pulls the cable that is attached to the flaps and moves them into the operating temp position. Thus pushing air thru the cooler. My flap is laying on my cooler and I do not see how air could pass thru it
flaps
Check your flaps they can be bent and easily damaged if some one has gorilla gripped it at some time in its life. Also make sure everything is in place and installed completly. The main flap rod should be spring loaded.
asymmetrical type 4,life
http://www.ratwell.com/dotmac/Pictures/Engine2/06-AsymmetricFlaps.jpg
Last edited by type4revolution on Sat Jul 04, 2015 9:27 am; edited 3 times in total
It works good. All it needs is a thermo and thermo bits.
I buy them new for my customers. You can get them from the type4 store or evwparts.com and you can find some good ones on the Vw classified site
interesting read
www.ratwell.com
For the moment....let it stay closed or wire it open?
if you have all the pieces to the thermostat system, it should be held open by the spring. You want the driver side almost laying over the cooler.
Greg- Dub Nut
It is laying on the oil cooler as of now. I don't understand this type 4 stuff.
can you post a picture of the flaps, as they are now. Although it sounds like they are in the hot position.
Greg- Dub Nut
This is how it sits when left alone.
I believe that is the "hot" position. that's where mine are, if you don't have a thermostat, that's how you want them to be. That way the flap can grab some of the incoming air and force it into the oil cooler.
Greg- Dub Nut
Ok, thanks.
» Do you have a thermostat?
» Mud Flap install
» Engine cooling
» 1700 pound mid engine VW Beetle
» **Plans** Bay Window Mud Flap Plans Revised
» Mud Flap install
» Engine cooling
