Dual Oil Relief Cases
Guys, I need help quick. I am in the process of rebuilding my engine out of a 71 super beetle. I think, (I could be wrong) the rear oil relief galley(by the flywheel) has the plunger (valve) in upside down! The reason I state this, is when I compress the short spring, plunger and screw in plug together, they measure more than the depth of the galley. My measurement of the galley is 1.36 inches deep. I would like to ask of you guys, if you could measure a dual relief cases you have laying around and see if this is the same measurement you get. All I have is 36hp cases.
Thanks for your help!
allan4570- Dub Noob
- Number of posts : 48
Registration date : 2008-12-15
Re: Dual Oil Relief Cases
No need for a reply. I got my answer from a fellow samba member. The valve (plunger) was indeed in upside down. I tried a magnet, but the valve (plunger) was stuck tight. So, I drilled into the center of the plug and when almost through the bit grab the plug and started spinning it. I then got a long sheet metal screw, got it started and simply pulled it right out. Now, I should have good oil pressure!
allan4570- Dub Noob
Holy Crap . Good thing you didn't blow up
» Using a Dual Kadron Single intake with dual 34's
» Update and Questions on dual carb conversion.
» dual carb question
» dual vacuum distributor vs single vacuum Weber carb
» Empi 34 epc dual carb kit
