1972 Super Beetle
+10
cavediver520
vwgirl
kindabored2
camch
14 posters
Page 1 of 2 1, 2  Next
1972 Super Beetle Empty 1972 Super Beetle
Post by Bugman114 Wed Mar 10, 2010 11:07 pm
well, i thought i'd start a thread on my newly aquired 72 super.  bought it a few days ago for $1K.  Lots of power, and lots of fun.  the front has lowering springs, so its a tad bit lower then the rear.  It needs some work, but thats just part of the fun.  I'll let the pics do most of the talking:
1972 Super Beetle 101_2616
1972 Super Beetle 101_2614
Brand spank me new springs:
1972 Super Beetle 101_2615
Needs new rubbers.........:
1972 Super Beetle 101_2618
........And paint Laughing:
1972 Super Beetle 101_2617
The 2085cc engine (78.4mm crank, 92mm pistons):
1972 Super Beetle 101_2610
And hopefully, i'll be slapping this beast on soon Twisted Evil:
1972 Super Beetle 101_2568
The wipers are slow as hell.  takes like 30 seconds to go from one side and back, lol Laughing.  a lot of the electrical stuff doesn't work.  it was origionally an A/C car, so i'm thinking when they ripped out the compressor, they may have accidentally messed up some of the wiring.  The following doesn't work:  interior light, speedo lights, vent fan, rear deforster, and a few other things.
One thing thats really awsome, is that the rear window has the rear window defroster tabs still attached.  Every rear window i have ever seen with defroster lines (including my 74 super, as well as junkyard bugs), have always had one or both tabs broken off.  i will definately get the window deforster working Twisted Evil.
and yes, i do plan to replace the missing tin pieces, so quit asking Laughing.  i also plan to replace that POS empi shroud.  drove the thing down the road, and it overheated after 30 mins of driving.
1972 Super Beetle Empty Re: 1972 Super Beetle
Post by DiggerD Wed Mar 10, 2010 11:16 pm
Looks pretty solid. If you need any parts, lemme know. I still have a pretty good pile of 71-72 super stuff.
Post by Bugman114 Wed Mar 10, 2010 11:22 pm
the other day while driving, all of a sudden i hear a light clicking noise. 2 second later i hear a loud clacking, and about another two seconds later i hear a very loud CLACK CLACK CLACK. It took me a second to realize what was happening, and i shut her down. popped the right side valve cover, and out came the valve retainer, and pieces of valve spring. i called AAA and they towed me home (BTW, EVERYONE NEEDS TO GET AAA. it costs $120 a YEAR for the best service, with 200 free towing miles). anyhoo, got the engine out, tore it apart, got the head and the piston out. you can tell by the marks on the piston, that when the retainer came off, the piston started smacking the valve, and since the valves aren't perpendicular with the piston, and are at an angle, the piston hit the valve, bent it, hit it at another angle, bent it some more, and over and over, till it broke off, moved over, the flat part of the valve hit the exact center of the piston, the vbusted end of the valve then punched thru the head, right in the center, between the valve seats, and since the valve was bent, it punched a curved tunnel into the intake. so basically the head is toast, but amazingly the piston is fine. had to chip a few of the aluminum pieces off, and a little polishing, but it was fine.
turns out, when i went to push on the valve springs, they are crazy soft. i was able to push the valve down with one finger. the valves must have been floating like crazy. anyhoo, i plan to get new heads soon, with bolt together solid rocker shafts, stock rocker arms, and swivel foot adjusters. i still haven't decided between single HD valve springs, or dual. anybody got any ideas on that?
Post by Bugman114 Wed Mar 10, 2010 11:23 pm
DiggerD wrote:Looks pretty solid. If you need any parts, lemme know. I still have a pretty good pile of 71-72 super stuff.
Awsome. i will prolly need some stuff for it soon. haven't really dug into it yet, but i know i'll prolly find some suprises. Laughing .
The floor pans in it are perfect. absolutely no rust holes. not even under the battery tray. the only issues with the pans, are it seems at some point somebody hit something, as the battery tray area of the floor pans, on both sides, and dented in. as if somebody either hit something, or somebody jacked the car up on the floor pan. i'll prolly pound those out later. otherwise, there aren't any rust issues. the heater channels are also perfect. no rust, and still has the origional paint. that sure saves me a lot of work, lol
Post by vwtattooed Thu Mar 11, 2010 11:01 am
Ummmm....wasn't that engine supposedly rebuilt by IAS? if so remind me never to have them work on my car! and by the way that's a CUTE turbo...if you feed and water it and give it vitamins and say your prayers, it will grow up into a big one someday! lol!
Number of posts : 798
Post by camch Thu Mar 11, 2010 1:41 pm
if it was rebuilt why didnt you take it to them before braking it down,just wondering
camch
camch
Number of posts : 660
http://yubuggin.com
Post by 56HAVOC Thu Mar 11, 2010 1:48 pm
WOW I'm surprise at IAS I thought they knew there stuff over there. Embarassed
Number of posts : 1703
Post by Bugman114 Fri Mar 12, 2010 1:52 pm
well, aperantly the motor was built two years ago and it just sat. so when i popped the valve cover open there was rust, and the springs were pretty weak. the car belonged to a customer, and IAS were just trying to sell it for him.
Also, they told me that stock springs woth a 120 cam would be fine, but everywhere else i read, says that with a 120 cam dual springs it a must, or else you float valves and break springs. so i'm not sure. i'll prolly go with dual springs just to be on the safe side tho. it had stock heads, so i'll prolly go with some 041's or something anyway. kinda pointless to have a big ass motor with such tiny valves Twisted Evil
Post by kindabored2 Fri Apr 02, 2010 8:19 pm
So how did the new heads work out?
kindabored2
Number of posts : 8
Registration date : 2010-03-07
Post by vwgirl Fri Apr 02, 2010 8:37 pm
I had a valve spring break on me once... on thanksgiving day on the interstate... fun stuff!
vwgirl
Number of posts : 332
Post by Bugman114 Fri Apr 02, 2010 9:02 pm
i just went today, and picked up the heads (042 MOFOCO heads, bearly used, had about 10 miles on them), along with a set of shortened Chromoly pushrods, two sets of thermostat flaps, an origional functioning alcohol thermostat, and two hoover bits (the little L shaped tin piece that bolts to the oil cooler, that everyone seems to throw away, lol), and all for $300.
Last week i picked up a set of 1.25 ratio rockers, with the adjustment on the pushrod side, from stockornaut. really nice looking. so today i changed the rocker studs from the stock size, to the chromoly ones that came with the rocker shafts (they were a little longer, because the rocker shafts and blocks are thicker). cleaned up the motor a bit, resealed the barrels to the case, but just when i got to the last piston, i couldn't find one of the friggin piston pin retainer clips Evil or Very Mad . so i'm pretty much on stand still till i get another friggin clip, or i find one lying around.
I'll try to post up some pics later tonite.
-Mike
Post by Bugman114 Fri Apr 02, 2010 11:43 pm
I just dropped my bro off at work (he works night shift), and as i'm walking across my driveway, i see the missing clip, lol. turns out, i had placed the clip on top of the motor when i took it out, but when i rolled the motor out to work on it, it must have fallen off, lol. anyhoo, i was soo happy, i got the clip in, and the pistons, and cylinders on. hopefully tomorrow, i'll get the heads, and everything back together. anyhoo here are some pics, enjoy:
Motor:
1972 Super Beetle 101_2637
1972 Super Beetle 101_2636
Here are those smexy big valve heads:
1972 Super Beetle 101_2647
1972 Super Beetle 101_2646
1972 Super Beetle 101_2639
And here is a comparison betweem stock heads, and the 042's notice the difference in port sizes:
1972 Super Beetle 101_2645
1972 Super Beetle 101_2643
the chromoly shorter pushrods:
1972 Super Beetle 101_2648
Stock VS chromoly:
1972 Super Beetle 101_2649
And then of course the smexy 1.25 rockers, with HD bolt together shafts. notice the adjustment at the pushrod side, intead of the valve side (crazy backwards performance stuff Laughing ):
1972 Super Beetle 101_2640
1972 Super Beetle 101_2641
Here are some pics of the AC stuff on the car:
Under dash console. still have evaporator inside:
1972 Super Beetle 101_2654
Condensor:
1972 Super Beetle 101_2657
1972 Super Beetle 101_2658
oh, and heres some pics of the hoover bit i finally found. found two, so i got them both, lol:
1972 Super Beetle 101_2663
1972 Super Beetle 101_2662
and here's something i thought was dumb. the rear saddle mount for the tranny, is a solid mount. no mounts at all. the metal bracket, bolts to the tranny, and then the frame horns??? but the really stupid part, was that they left the stock rubber front mount at the nosecone, and its halfway ripped off, lol:
1972 Super Beetle 101_2650
Post by Bugman114 Fri Apr 02, 2010 11:44 pm
Oh, and pay no mind to the dates on te pics. my camera is messed up. i wasn't holding out on the VW porn, so don't hate, Laughing
Post by cavediver520 Sat Apr 03, 2010 2:04 am
Is it just me, but aren't those rockers on backwards? I wouldn't suggest running them like that. Shocked
cavediver520
cavediver520
Number of posts : 69
Post by Attorney Isaiah Loophole Sat Apr 03, 2010 9:14 am
cavediver520 wrote:Is it just me, but aren't those rockers on backwards? I wouldn't suggest running them like that. Shocked
Its just you
Post by vwgirl Sat Apr 03, 2010 9:30 am
I am with you... they are crazy backwards looking...
vwgirl
Post by Attorney Isaiah Loophole Sat Apr 03, 2010 9:35 am
1972 Super Beetle 389558
Post by Bugman114 Sat Apr 03, 2010 10:22 am
they are 1.25 ratio rockers with bolt together HD rocker shafts. notice the lack of clips, or wavy washers. instead of clips, there are two end caps, that bolt to the shaft.
Stock rockers:
1972 Super Beetle 395440
Not stock rockers (these are an okarassa style for 36hp, but just look at the rocker arms themselves):
1972 Super Beetle 389560
From what i understand the reason they change the adjustment to the pushrod side, instead of the valve side, is to have the larger "foot" on the end so they won't wear out the end of the valve, which is good especially in a high HP, and high Revving motors, and motors with higher spring pressures. also the pushrod adjustment screws, and nuts are chromoly as well.
on my particular heads, i have dual HD (heavy duty) valve springs, as well as a 120 cam. using stock rockers, and stock pushrods wouldn't have lasted at all, because of the higher lift cam and the much higher spring pressure, of dual springs. aluminum pushrods would have bent, and the stock rockers would haave most likely broken clips and those wavy washers. soo i am using chromoly puushrods, which won't bend, and are a LOT tougher, and the ratio rockers will also give me a little more HP. the toughest rocker arm/ shaft combo there is are roller rockers. they still have the adjustment on the pushrod side, and on the valve side, there is a roller, so there is absolutely no side load on the valve. the problem is, that roller rockers start at $400 a set Shocked . the most common i've seen are pauter. here's a pic:
1972 Super Beetle 1498
Post by vwgirl Sat Apr 03, 2010 10:38 am
Makes sense, but it still "looks" backwards Smile
vwgirl
Post by tito Sun Apr 11, 2010 4:11 pm
well? whats the word? is this beast up and running yet or what man?
Number of posts : 205
Post by Bugman114 Mon Apr 12, 2010 12:26 am
not yet. between two jobs and other stuf, i've been a little behind. but i finally got the new 042 heads, rockers, and everything together, so now its officially a long block, lol. i'll post up some pics later. hopefully tomorrow, if all goes well, i'll atleast get the motor together, and maybe even back in the car Shocked , lol.
Post by Bugman114 Mon Apr 12, 2010 11:21 pm
Alright, time for some VW porn:
Here's the long block:
1972 Super Beetle 101_2827
Here's those crazy backwards really sexy rockers:
1972 Super Beetle 101_2828
Painted tins (well its actually primer Embarassed , but it'll be fine for BAP):
1972 Super Beetle 101_2830
1972 Super Beetle 101_2829
Pic of the old shitty high flow schadek pump. i replaced it with a brand new stock sized schadek pump:
1972 Super Beetle 101_2831
Gittin some tins on:
1972 Super Beetle 101_2832
1972 Super Beetle 101_2833
Poor mans assembly lube Laughing :
1972 Super Beetle 101_2834
and finnaly this is where i finished for the day (a few minutes ago):
1972 Super Beetle 101_2851
1972 Super Beetle 101_2852
1972 Super Beetle 101_2853
Perfect fit (gotta love that german tin):
1972 Super Beetle 101_2854
Bought some new 10mm tin screws (M6 1.0 thread pitch)
1972 Super Beetle 101_2855
still shines up nice:
1972 Super Beetle 101_2856
Well, it only looks good from the side of the motor you see, but thats all that matters, lol:
1972 Super Beetle 101_2858
Got rid of that damn EMPI shroud:
1972 Super Beetle 101_2859
WTF???
1972 Super Beetle 101_2860
Not so nice now is it:
1972 Super Beetle 101_2861
tommorow i hope to get everything finished, and hopefully in the car and take it for a test burnout........err, i mean test drive Twisted Evil
Post by Grifspop Tue Apr 13, 2010 9:30 am
German Tins, looks good. I think the chrome shroud looks like garbage, definetly not a good piece for a real motor
Post by Bugman114 Tue Apr 13, 2010 11:49 am
yeah that shroud is a piece of crap. By starring at that shroud and a german shroud, you can easily tell that the quality just isn't there. lots of little things missing.
but i'm fixing to go out, and try to get the motor 100% finished and in the car. wish me luck
Post by tito Tue Apr 13, 2010 3:31 pm
very nice man. makes me want to hustle on Sophia but... priorities abound.
