Turn Signal Question
+3
fearthefat138
AirKewled
7 posters
I replaced my turn signal not too long ago, and when I went to use it, the left works fine, but the right does not. When I try to use it on the right, the GEN light comes on, and it will not blink at all. The left side does not have that problem and works fine. I am thinking that there is something making contact with some metal inside. Does this sound possible?
AirKewled- Dub Noob
- Number of posts : 13
Registration date : 2009-01-28
Re: Turn Signal Question
Check your turn signal relay switch.
EngineerTEN- Dub Nut
- Number of posts : 358
Forgot to mention that I had already replaced that! So that was not it either. It baffles me...
AirKewled- Dub Noob
trace the wires they are crossed if the gen light comes on
fearthefat138- Dub Nut
- Number of posts : 275
Grounds, Grounds. When the ground is open the voltage tries to find a way there and it does weird thinks.
rpm750 wrote:Grounds, Grounds. When the ground is open the voltage tries to find a way there and it does weird thinks.
Grounds - very good start - I had a similar issue and it was ground related.
check the blinkin relay..ckeck the ground wires to and from blinkers and make sure you have the rite bulbs
» Turn signal help
» Turn signal flasher buzzing
» Turn Signals
» Rattling noise when I turn off 68 bug
» Turn Signals
