Turn Signals
Turn Signals
Post by peregrine67 on Wed Jun 30, 2010 8:09 pm
Somebody refresh my memory, please. It's been a while.
I'm trouble shooting my turn signals. All the running lights work when I turn the lights on. But when I turn the signals on I get a really fast relay click, 5-10 clicks per second, and no signal lights.
bulbs?
relay?
something else?
Number of posts : 1343
Re: Turn Signals
Post by zabo on Thu Jul 01, 2010 9:16 am
id check your grounds before you get too far. also double check all the bulbs look good and are in correctly
Re: Turn Signals
Post by peregrine67 on Thu Jul 01, 2010 9:33 am
zabo wrote:id check your grounds before you get too far. also double check all the bulbs look good and are in correctly
Each signal housing should have it's own ground, correct?
If the running lights work doesn't that imply that the housing is grounded properly?
I'll check all the bulbs tonight.
Re: Turn Signals
Post by bumblebuggy on Thu Jul 01, 2010 11:18 am
I'd guess relay but I'd start with replacing the bulbs on one side. Cleaning the grounds couldn't hurt either.
Re: Turn Signals
Post by peregrine67 on Thu Jul 01, 2010 12:11 pm
I'll probably disassemble more than I have to in order to figure it out but no worries. People will just have to get used to hand signals for a few days.
Re: Turn Signals
Post by 68buggirrl on Thu Jul 01, 2010 3:37 pm
^ haha thats what i do for my Right turns.
I had the same issue on my 68 beetle. I cleaned the ground on both sides and replaced the relay.
Only left works. But when all lights are on they all work. Turns on right just doesnt. So idk. lol
I would def clean them up sand the terminals too.
68buggirrl
Number of posts : 301
Registration date : 2010-03-20
View user profile http://www.facebook.com/?ref=home#!/bimmergirrl
Re: Turn Signals
Post by ASBug on Thu Jul 01, 2010 4:54 pm
peregrine67 wrote:I'll probably disassemble more than I have to in order to figure it out but no worries. People will just have to get used to hand signals for a few days.
I was using had signals when the ASBug's signals were down.
It was scarry how many people would wave back when I was signalling a left hand turn.
My RHD's front socket is corroded for the right turn signal and I have been tempted to do a hand signal, but I have no Idea how to from the other side of the car....
LOL
Re: Turn Signals
