Found the problem
Found the problem Empty Found the problem
Post by PeeWeeMan91 Sat Mar 17, 2012 2:15 pm
Found the problem Af911713
PeeWeeMan91
PeeWeeMan91
Number of posts : 567
Found the problem Empty Re: Found the problem
Post by pwmcguire Sat Mar 17, 2012 3:18 pm
Yeah, that spark plug looks a little fouled Very Happy
Number of posts : 787
Post by PeeWeeMan91 Thu Mar 22, 2012 8:21 pm
Anybody do a cheap valve replacement job
PeeWeeMan91
PeeWeeMan91
Post by Attorney Isaiah Loophole Thu Mar 22, 2012 8:29 pm
Doodle Bugg won't do it for you?
Post by PeeWeeMan91 Thu Mar 22, 2012 8:32 pm
Haven't talked to him.
PeeWeeMan91
PeeWeeMan91
Might try him
PeeWeeMan91
PeeWeeMan91
Post by Attorney Isaiah Loophole Thu Mar 22, 2012 8:40 pm
The set he rebuilt for me turned out super nice
Post by PeeWeeMan91 Thu Mar 22, 2012 8:43 pm
If I can get that valve replaced and just do my connecting rods as some are past the murrs guide so. Replace those and just that valve will save me a penny and can get jack back out on the road ASAP. Miss not driving the bug in this warm weather
PeeWeeMan91
PeeWeeMan91
Post by Attorney Isaiah Loophole Thu Mar 22, 2012 8:49 pm
I would build both heads
Post by PeeWeeMan91 Thu Mar 22, 2012 8:52 pm
Both. Ok just too match them. Sounds like a good idea. Called doodle and left a message
PeeWeeMan91
PeeWeeMan91
Post by Bugman114 Fri Mar 23, 2012 12:15 am
replace all of the valves. not too expensive. and if you have an oven, and a can of liquid nitrogen, you can do the valve guides yourself. not hard, i've done it a few times. i just used a 1/4 extension (the fat part), to pound them out. to install i just froze the guides in the freezer overnight, and when i was ready, i put the heads in the oven, and crank that bitch as high as it will go, and as soon as you take the heads out, give the guides a quick spray of nitrogen, and put the guides in. some light tapping and they go right in.
Post by DOODLE BUGG Fri Mar 23, 2012 8:23 pm
hey i know that doodle bugg
http://bugglife.com
