There's your problem.
There's your problem. Empty There's your problem.
Post by bumblebuggy on Thu May 17, 2012 1:22 pm
So I pulled the engine out of the Jolly Rancher today to see why it's making a strange "tinny" noise under load and this is what I found in the trany bell housing...
There's your problem. 576793_3618993246345_1619336065_2784649_1646419917_n
There's your problem. 579455_3618997006439_1619336065_2784652_853941583_n
It appears the flywheel is rubbing. and I'm not sure why. End play seems good. All the bolts holding the engine in were tight. Put a socket on the gland nut and it seems alright (no where near the ammount of torque needed but not loose). Any ideas?
There's your problem. Empty Re: There's your problem.
Post by vw57drvr on Thu May 17, 2012 3:03 pm
If it is nowhere near the correct torque, Im not sure how it is staying on. They usually come off and cause more damage. How much torque are we talking? I bet if you tightened it down completely, it wouldnt rub anymore. On a side note, how long have you been running that throw out bearing? Ive heard bad things about those. Thats the new sachs design isnt it?
Post by rpm750 on Thu May 17, 2012 7:38 pm
Sorry you had this problem but congrats on finding it now and not out in Texas or somewhere like that! Now that trip will be worry free!
Post by bumblebuggy on Thu May 17, 2012 7:56 pm
rpm750 wrote:Sorry you had this problem but congrats on finding it now and not out in Texas or somewhere like that! Now that trip will be worry free!
Cept I don't know why it's doing this. Bearing? Streched gland nut!?!? Dowel pins?
Post by bumblebuggy on Thu May 17, 2012 8:13 pm
Aftr a little more samba research, it appears this engine is likely hosed. If the flywheel has ovaled some holes(my assumption), it seems likely the crank, bearings or both may have been damaged.
Post by fluxcap on Thu May 17, 2012 8:48 pm
Well that sucks! Is it a 4 or 8 pin setup? If it's a 4 pin set-up, maybe the bearings are ok, and you can just get new holes redrilled???
Post by rpm750 on Thu May 17, 2012 9:13 pm
Sounds like its torque tool time. Remove the glane nut and do some inspecting. Hope it's not toast.
Post by bumblebuggy on Thu May 17, 2012 10:31 pm
Need to get the tools to pull it from dad should know by tomorrow night.
Post by rpm750 on Fri May 18, 2012 6:55 am
Doesn't look like it was leaking oil. I think if it were a bad bearing it would loose some fluid b/c the crank is moving around and the seal would have a gap when this is happening.
Post by bumblebuggy on Fri May 18, 2012 8:17 am
rpm750 wrote:Doesn't look like it was leaking oil. I think if it were a bad bearing it would loose some fluid b/c the crank is moving around and the seal would have a gap when this is happening.
Still...trying to salvage it to make a 4000 mile trip seems a little sketchy to me. I did a compression check and all the cylinders are around 100psi except #2 which is @ 87. So I'm leaning towards building another 1600 as I have most of the parts to throw one together. I'd hate to throw a band aid on this one to have it grenade somewhere in west Texas. Sucks this happened a couple weeks before the trip but better here than on the side of the interstate.
Post by camch on Fri May 18, 2012 1:52 pm
Have you pulled the flywheel off. If so sends picture we might be able to drill with larger pins
camch
camch
Number of posts : 660
Post by bumblebuggy on Fri May 18, 2012 2:27 pm
camch wrote:Have you pulled the flywheel off. If so sends picture we might be able to drill with larger pins
I will be pulling it tonight. I have a couple more flywheels in garage but now my concern is, if it is/was coming loose, it's put a side load on the bearings and crank which has likely stressed the entire engine. Setting out on a 4000 mile trip with a potential time bomb in the rear doesn't seem all that appealing. But I'm not an engine expert so I really don't know the extent of the potential damage. As of right now, my plan is to build/buy another 1600 longblock. I have a case/crank/rods/heads I just need some 40over bearings, P&C, Sand seal, and maybe a new cam and lifters. Not sure I trust myself though. I've taken several engines apart. Just never put one back together.
Post by camch on Mon May 21, 2012 10:14 pm
if you deside to take apart let me know after the show
camch
camch
Post by bumblebuggy on Tue May 22, 2012 1:12 pm
I bought a rebuilt 1600 because of time constraints. I will be pulling the other engine apart for rebuild after I return from Cali.
