Voltage Regulator
Voltage Regulator
I'm on my 3rd one...2 from O'reiley, so I won't be going back there! Any suggestions?
VW12step- Dub Nut
- Number of posts : 499
Re: Voltage Regulator
is your gen. working right.i went threw sum voltage regs. bout 2 years ago and couldnt figr out y.foundout that it was my genarator was bad which was frying my voltage reg. the same will do it if you put a new gen. on ur bug with a bad voltage reg. ive dun both ways.and finally put a new gen. and volt.reg. on at the same time and never had the problem again
one wire alternator out of a 76 no more problems with gens or voltage regulators
Got mine (12V solid state one) from the dealer in Dalton, Ga. (been in buisness since '63.)VW12step wrote:I'm on my 3rd one...2 from O'reiley, so I won't be going back there! Any suggestions?
There are ALOT of VW's in this county and they still stock a few things, get a bosch one.
I believe the FLAPS sell a no name points types.
Thanks for the information. I'll try to get a Bosch.
VW12step- Dub Nut
» Voltage Regulator Tip YouTube Vid
» How a Voltage Regulator Works YouTube Vid
» Adjusting a Voltage Regulator YouTube Vid
» How to test Voltage Regulator removed from the Alternator
» regulator for 6v gr11x generator
