How to test Voltage Regulator removed from the Alternator
How to test Voltage Regulator removed from the Alternator Empty How to test Voltage Regulator removed from the Alternator
Post by Heinz57 Mon May 16, 2011 7:07 pm
Does anyone know how to test a voltage regulator that has been removed from the Alternator with a meter? I suspect it is bad due to a reverse of polarity at the battery. A freak accident and I don't want to talk about it. After the incident, I corrected the cables and the car started fine, but of course the Alternator light is on. I checked the voltage going into the battery and its a steady 12.5 volts from idle to 4000 rpm's. It used to charge at 13.2 - 13.5 volts at idle.
Or does anyone have a regulator for a Motorola AL82, its the White Box Style that sits on top of the alternator that I could try to meter out or run?
Heinz57
Heinz57
Number of posts : 374
