Turn-signal sideview mirrors
Turn-signal sideview mirrors Empty Turn-signal sideview mirrors
Post by JWILL Sun Feb 25, 2024 8:24 pm
Not a huge fan of plastic sideview mirrors, but at $25 and this neat trick, it may be worth your consideration.
The hardest part is drilling the hole where the wire will be hidden by the rubber while avoiding the tension screw:
Turn-signal sideview mirrors 20200811
I apologize for the poor picture, but this is the best that I have from inside the base.
Turn-signal sideview mirrors 20200812
Then you drill a hole where your LED is to mount and fish out your wires from behind the mirror.
Turn-signal sideview mirrors 20200810
JWILL
JWILL
Number of posts : 110
Registration date : 2015-04-28
http://www.superbeetlesonly.com/forum/index.php?showuser=5245
Turn-signal sideview mirrors Empty Re: Turn-signal sideview mirrors
Post by JWILL Sun Feb 25, 2024 8:31 pm
You might already have mounts for your sideview mirrors. But if you do not here is what I did:
First use masking tape to draw where you want your mirror to mount. Notice I made a few changes before actually drilling.Turn-signal sideview mirrors 20200813
Next I drilled my pilot hole and one for the wiring, added a grommet for the wires and removed the tape.
Turn-signal sideview mirrors 20200814
Bracket mounted and wire threaded through the hole and into the car at the bumpstop.
Turn-signal sideview mirrors 20200815
*** I did have these crack and break while sitting under a cover and at a friend's house for two years- so when I reinstalled, I added a little JB Weld in the corners of the base, which has held pretty well for a cross country trip and ~8months at the posing of this thread.
JWILL
JWILL
Post by JWILL Sun Feb 25, 2024 8:35 pm
Here is the finished product.
Turn-signal sideview mirrors 20200816
Wish I found a brighter LED as these are almost worthless during the day, but at dusk these begin to look great!!!
Turn-signal sideview mirrors 20200817
JWILL
JWILL
