What did you do to your volkswagen today?
+85
wagtag
Johnny
ryneb21
vdubyou709
sdmjam
wdstang
R33ce97
jotty
shaky
Slim4life
runabout199
ultralite
jtcap
56rag
jim conner
limabean79
macollins105
ridikas
reprobate3
Brooks424
Murdock00
Major62
damon23
60andslow
Attack chicken
ibjamn
johnvalkennedy
laith
DubDawg2579
bulldawgdude
vdubbers
uBER_SLO
hly3rd
RomanBug
Gabass
720boy
cjvan71
bayboy87
MRJEL
68beetlebug
ggaagg57
guytonbug
Hookdriver
rican11
Heinz57
yayarudy
earlyvwfanatic
PeeWeeMan91
Laz
fried_chicken
redneck_davis
type901
89 posters
Page 1 of 34
Page 1 of 34 • 1, 2, 3 ... 17 ... 34
Replaced the Spare tire well and cleaned up the apron and some rust under the well. Got dark so no pics of the finished product.
type901- Dub Crazy
- Number of posts : 543
Re: What did you do to your volkswagen today?
Coming along nicely Phillip!
I got the crusty dusty speedometer I bought at Bulli cleaned up. Replaced the gels, painted the needle, and painted the inner circle and outer ring. When I had the needle off, I re-adujsted it just a tad to account for my new slightly smaller than stock front tires. It's now off a few mph in the 10-30 mph range, but pretty close in the 40-60mph range. Unfortunately, the needle starts getting pretty bouncy around 60mph . Oh well, I can just look at the GPS to see how fast I'm going if I hit the interstate. At least the speedometer looks nice now!
Also replaced my hi/lo beam relay since the old one crapped out and decided to work only when it wanted to. Also took my turn signal switch apart and re-bent a few connections in there so I can now signal a left hand turn without having to hold the stalk in the sweet spot! While I was at it, I noticed the cancel ring was mounted on the steering wheel incorrectly, so I fixed that and now also have blinkers that turn themselves off when they are supposed too
Eric that speedo looks brand new. Looks great.
I decided to stop fearing the rear corner and welded it in. Corner radius was off and had to shorten a flange by 1/16th so my Hinge carrier will look level. This is not the right Hinge carrier, so I am just test fitting with it.
Took all sorts of rigging to get the opening right.
Starting to look like a bus from the rear now.
type901- Dub Crazy
The speedometer looks great, but I just know the bouncy needle will drive me crazy. It's not just bouncy, I mean it's all over the place around 60mph. Up to 60 it's fine, but after that it starts looking like a radar.
Therefore I messed with the original some more to see if I could get it working again. Got it re-installed, and will test it against the GPS tomorrow.
The new corner is looking great! I've got some rot to fix on the lower 3 or so inches of my corners, but hopefully won't have to replace the whole panel.
For as great as everyone says those green panels are, you (and others I've read) sure do have a hard time getting them to go on without some tweaking. Everyone is out of the funky green lower door skin for the front passenger doors. I tried autocraft, but it doesn't look like they are making this one yet either.
Luckily I've still got plenty of interior work to keep me busy finishing my headliner to wait on that door skin to come back in stock.
At least it is not screaming when it gets to 60, talk about scaring you to death. You are borderline making that thing to comfortable for my taste, aren't there suppose to be things that do not work in them??
The only panel that fit well was the long rocker, it was pretty dead on. Everything else is close but still takes some managing to get right.
That corner really did not look terrible at the hatch but once I opened it up the inner structure was gone so this took probably 30 hrs to complete.
I have a guy suppose to ship me a passenger door so You can get these repair panels if it gets here in the condition he has described.
type901- Dub Crazy
Installed my ebrake!!! Kinda nerve racking driving a 50 year old car around with a single circuit master and no ebrake! Also finally got the deck lid put back in. Looks pretty good. I think once I buff out the original paint, it should match a little better.
ping349n- Dub Nut
- Number of posts : 344
You know how it goes, you fix one thing, and something else stops working!type901 wrote:At least it is not screaming when it gets to 60, talk about scaring you to death. You are borderline making that thing to comfortable for my taste, aren't there suppose to be things that do not work in them??
type901 wrote:The only panel that fit well was the long rocker, it was pretty dead on. Everything else is close but still takes some managing to get right.
That's part of the reason I keep putting off the metal work on my bus, scared I'll start digging deeper and find parts totally gone once I dig in. I'm worried the smaller rust areas I have on the nose will turn into bigger projects, but I'll eventually get to them. And I got a few frame sections I'll need to replace eventually.
Yeah, I'd definitely like to buy that door piece if you don't end up needing it, hopefully the door coming to you will be mint.
I have to fix my ebrake. Stopped by my parents the past weekend and replaced all the rubber fuel lines for good ol preventative maintenance. Then discovered the push button for the ebrake had stripped its threads and popped out of the handle leaving it non-functional. Didn't have time to investigate it, so that'll have to wait. See my text above about fixing one thing, only to have something else brake.ping349n wrote:Installed my ebrake!!! Kinda nerve racking driving a 50 year old car around with a single circuit master and no ebrake! [/img]
But the damn horn works! I think that is the first thing Eric works on when he gets a project!
rpm750 wrote:But the damn horn works! I think that is the first thing Eric works on when he gets a project!
Well it is very important to have a working horn while driving thru the mountains to use during the tunnels!
And Phillip the bug and bus are looking good!
ping349n wrote:
That looks awesome. Nice car.
Jon65- Complete Dub Addict
- Number of posts : 875
Heck yeah, you never know when some bonehead is going to stop in the middle of a two lane road and attempt a 8point u-turn. Gotta let them know you ain't cutting em any slack.
noticed a knocking from my rear wheel at low speeds, maybe its there at higher but cant tell.
Pulled the drum and everything looked fine- tightened up everything while i was there, trans oil good... noise still happening
Side bars came in. JCW overstocked and sold on ebay 50bux free shippin. Local parts store ripped me a new one w the 14dollar can of bedliner paint though. . 6 large sheetmetal screws failed the jump test. Spilt; my beer but stayed on my feet
redneck_davis- Dub Nut
- Number of posts : 188
Mounted up the new rims on the SP2.
BKiller- Dub Crazy
- Number of posts : 687
Prepped it to be taken to the shop tommorow.
Empi crap. Aint nothin the welder wont fix
Shit it's almost all carp now a days unless u go with a company that isn't a cookie cutter store like empi
- Number of posts : 1416
OEM all the way.
BKiller wrote:Mounted up the new rims on the SP2.
The SP2 is looking real nice with those wheels!
Jacked the frontend up and took the front hubcaps off, wow I got a lot more to do lol.
fried_chicken- Dub Nut
- Number of posts : 336
Found out my dual carbs are shot.
Now I gotta remove them from my signature.
Decided to stop crying about a perfect door and fixed the one that came on the bus.
Very time consuming, but the end result is ok with me.
type901- Dub Crazy
» Met yet another PO today...
» Cars show today at Dixie land in fayetteVille Today till 5
» Volkswagen TV
» Volkswagen TV
Page 1 of 34
