Oil dripped after change.
I changed the oil in my bug today, put everything back together, wiped the underside and went back inside the house. Came back outside 3 hours later and saw a couple drips of oil. Is that normal?new gaskets and strainer too.
ridikas- Dub Nut
- Number of posts : 377
Re: Oil dripped after change.
U put new copper rings around the studs and drain plug
- Number of posts : 1416
ridikas- Dub Nut
Where is the oil coming from
The drips don't line up with the sump plate. I'll look in the morning
ridikas- Dub Nut
Since the drips don't line up with the plate, maybe you spilled a little bit when filling and it just worked down around the cylinder tins?
It's dry under the sump plate and the drips are offset by a couple inches. Maybe im crazy
ridikas- Dub Nut
If there is notmabigger puddle under there in the morning I go with the idea that there was some spill over. Possibly from the draft tube.
Cave Man- Dub Nut
- Number of posts : 333
» Oil change tip.
» Bug-a-Paluza time!!
» Vert wheel change
» Fastetest belt change on volkswagen
» Colin (Amskeptic) Monday 28th Pizza and beer Venue Change!!!
» Vert wheel change
