part name - 65ish buggy front susp
Post by kyleb on Sat Jul 13, 2013 2:13 am
I have a list of torque specs for the front end of my buggy. The front spindles are aftermarket, but I don't know that changes anything.
What is the name of the 2 bolts that hold the spindle to the suspension? What would be the torque specs on it? I just tightened them quite a bit, then realized that they pivot with the suspension going up/down
this isn't the best picture, it only shows one end of the bolt, not the end with the nut.
kyleb
Number of posts : 22
Registration date : 2013-05-26
Re: part name - 65ish buggy front susp
Post by sploval53 on Sat Jul 13, 2013 2:43 am
King or link pin. Always get the two confused. Pretty sure they don't get torqued just the two bolts that hold them in
Number of posts : 1416
Post by sploval53 on Sat Jul 13, 2013 2:45 am
Give me a shout. I live in fayetteville. And have been wrenching on vws for about 10 years. 6789081273
Post by Attorney Isaiah Loophole on Sat Jul 13, 2013 10:14 am
Thats the link pin there are two per spindle......king pins are the ones that are straight up and down.....all you do to tighten link pins is loosen the pinch bolts and spin the link pins til theres no play.....spin one way and it loosens and the other way tightens.....once there is no play tighten the pinch bolts back down
Number of posts : 4927
Post by kyleb on Sat Jul 13, 2013 12:34 pm
Cool, thanks Attorney
Sploval53 - I was the guy that came by your house the other day with the hub/brakes
kyleb
