axle(trans side) removal - 6rib
Hello, I couldn't seem to find a video or anything online to help me figure out how to remove the axles from my trans.
6 rib 091 bus trans - with the 6 bolt axles
Both ends are out of the hub. I can't seem to get them out of the trans.
kyleb- Dub Noob
- Number of posts : 22
Registration date : 2013-05-26
Re: axle(trans side) removal - 6rib
Not sure what you are saying there. If both ends are out of the hub, the axle will be on the floor!
If you mean both axles are out of the WHEEL hubs, but stuck in the transmission hubs, Did you remove those bolts? (on the transmission end of the axles). If yes, just pop the side of the CV joint with a hammer, and it should turn loose. The bolts is all that holds them, but they do get lightly stuck in the flange.
MRJEL- Dub Nut
- Number of posts : 220
Yes, meaning each axle is hanging from the trans, no longer attached to the hubs.
Yes, i removed the bolts. Ill try hammering again.
kyleb- Dub Noob
kyleb wrote:Yes, meaning each axle is hanging from the trans, no longer attached to the hubs.
If the bolts are out, just pull down on the axles as far as you can. They should release from the tranny. but a gentle whop or two may still be needed. The bolts are all that fastens them.
MRJEL- Dub Nut
got it. turns out I was being to gentile. One good wack with a hammer did the trick. thanks
kyleb- Dub Noob
kyleb wrote:got it. turns out I was being to gentile. One good wack with a hammer did the trick. thanks
Great.
We "gentiles" tend to be to soft anyway! (smiley goes here).
MRJEL- Dub Nut
MRJEL wrote:kyleb wrote:got it. turns out I was being to gentile. One good wack with a hammer did the trick. thanks
Great.
We "gentiles" tend to be to soft anyway! ( ).
Fixed it for ya
Grifspop wrote:MRJEL wrote:kyleb wrote:got it. turns out I was being to gentile. One good wack with a hammer did the trick. thanks
Great.
Fixed it for ya
Preciate dat! How'd you do it? I couldn't find them!
MRJEL- Dub Nut
They're on the top bar of the Quick Reply
haha,
I kant spel good.
I kant spel good.
kyleb- Dub Noob
Grifspop wrote:They're on the top bar of the Quick Reply
But they don't come up when you hit "quote" thingy. There's a way I know. Kyle may have trouble speellinng. I'm just compooter stupid!
Anyway, Glad you got your problem solved Kyle!
MRJEL- Dub Nut
MRJEL wrote:Grifspop wrote:They're on the top bar of the Quick Reply
Mine are on the right when you hit the quote button.....
If I weren't so dense, I'd feel dumb right now!
All I needed to do was make the page fit the screen!
Thanks!
MRJEL- Dub Nut
» Door Removal
» Wheel removal
» oil fill removal???
» Rust removal by electrolysis (revisited) with detailed photos/info
» DECK Lid Removal
» Wheel removal
» DECK Lid Removal
