der BajaRod
der BajaRod
Been here a while & figured it's about time to start a build thread on it. It's a 76 standard w/bug-eye baja kit on it. Runs & drives but, has some minor issues.
These are when I picked it up back in Oct.
Last edited by brucerodz on Fri Apr 19, 2013 12:15 am; edited 2 times in total (Reason for editing : can't spell,)
brucerodz- Dub Noob
- Number of posts : 65
Registration date : 2012-12-22
Re: der BajaRod
Some of the interior:
Have more pics of where I'm at but, I'll get to those next time.
Til then,,,,,,,
Til then,,,,,,,
Last edited by brucerodz on Sun Apr 21, 2013 1:08 am; edited 1 time in total (Reason for editing : can't type)
brucerodz- Dub Noob
Re: der BajaRod
Looks good.
What kind of issues are you having, if you don't mind me asking?
Jon65- Complete Dub Addict
- Number of posts : 875
Re: der BajaRod
Thanks, Jon.
Issues: Need to reroute & tidy up the wiring a bit,,,,,,
Fuel tank vent line needs replaced. PO did lousy job of rigging it,,,,,,
Will also have to replace the flywheel seal soon.
brucerodz- Dub Noob
Re: der BajaRod
Cleaning up the dash by getting rid of the tore up cover. Just have to fill in the excess holes.
brucerodz- Dub Noob
Re: der BajaRod
PO used trailer lights for taillights. Those had to go so, having a set of LEDs rejected from another project, figured they could finally be put to good use.
Hole after old light removed.
Test fit the new lights.
Both in,
Make sure they light & look OK,
Both in,
brucerodz- Dub Noob
Re: der BajaRod
Next step,,,,fill in the holes & see what I can come up with for brake & turn signals.
Till next time,,,,,,,,,,,,,,,,
brucerodz- Dub Noob
Re: der BajaRod
Prepping the holes for fill in.
Remount the tails for the last time.
Holes semi filled in.
brucerodz- Dub Noob
Re: der BajaRod
Taking a short break from glasswork to start fabbing up some plates to fill in the dash holes,,,,,,,
For the right of speedo,,,
Just laid in place to see how it'll look,,,,
Laying out the left side plate,,,
Next,,,,finishing filling in the light holes & brake & turn signals & other side plate.
brucerodz- Dub Noob
Re: der BajaRod
Left side cover cut & trimmed:
Test fitting cover:
Test fitting both:
Test fitting cover:
Test fitting both:
brucerodz- Dub Noob
Re: der BajaRod
Nice.
Re: der BajaRod
A little late. .but the taillights I used on my blue Baja, red LED strips but were 3 function. Turn, brake, and running lights.. never used the turns just played with them.
My new one is running the stock rears. Been chasing wires still no luck. Anyone know which colors hook together on a stock 63
redneck_davis- Dub Nut
- Number of posts : 188
Re: der BajaRod
redneck_davis wrote:A little late. .but the taillights I used on my blue Baja, red LED strips but were 3 function. Turn, brake, and running lights.. never used the turns just played with them.
Such is,,,,,,,tho, I do have some ideas for the brake & turn signals.
brucerodz- Dub Noob
Re: der BajaRod
Working on the left tail,,,,,
And on to the right,,,,
Ooooops, not quite yet,,,,,
brucerodz- Dub Noob
Re: der BajaRod
Looks good
Murdock00- Dub Noob
- Number of posts : 53
Registration date : 2013-05-22
Re: der BajaRod
Back to the left,,,,
Right dash cover mostly done & mounted
Now!!!
Now!!!
brucerodz- Dub Noob
