help needed
+2
LungTube
airhead88
6 posters
Georgia Dubs :: Tech Talk :: Watercooled
help needed
how would i adjust the shifter linkage on a 92 jetta 1.8 5 speed
airhead88- Dub Noob
- Number of posts : 32
Registration date : 2009-06-06
Re: help needed
http://www.strictlyea.com/features/diyshifter.html
LungTube- Dub Nut
- Number of posts : 110
Re: help needed
thanks manLungTube wrote:http://www.strictlyea.com/features/diyshifter.html
airhead88- Dub Noob
Re: help needed
I need some help with a 91 Jetta, I recently purchased. It needs some wiring issues straightened out, among other things.
Re: help needed
bakertim2 wrote:I need some help with a 91 Jetta, I recently purchased. It needs some wiring issues straightened out, among other things.
Just smack the dash occasionally, should fix most of them! I do not think I have ever owned a vw without some kind of wiring problems. The 80's-90's were the worst. What are the problems with it?
Re: help needed
It doesn't have power to the switch side of the starter and I cant hear the fuel pump running.
Re: help needed
Auto or manual? if its auto then neutral safety switch either way make sure your seat belt is connected(on). its got a switch in it and not clicked no start.
LungTube- Dub Nut
Re: help needed
if it has the shoulder belt in the door, the car will not start unless the belt is hooked up! as stated also check neutral safety. most likely seat belt tho.....
- Number of posts : 798
» Unique use for restoring VW's. Using VW's as a tool for learning and faith
» Tow Bar needed
» Prayers Needed
» Major help needed
» Prayers needed!!!
» Tow Bar needed
» Prayers Needed
» Major help needed
» Prayers needed!!!
