help needed
help needed
Post by airhead88 on Tue Oct 05, 2010 10:28 pm
how would i adjust the shifter linkage on a 92 jetta 1.8 5 speed
airhead88
Number of posts : 32
Registration date : 2009-06-06
Re: help needed
Post by LungTube on Fri Oct 22, 2010 9:21 pm
LungTube
Number of posts : 110
Re: help needed
Post by airhead88 on Tue Oct 26, 2010 12:28 pm
airhead88
Re: help needed
Post by bakertim2 on Tue Jan 04, 2011 8:50 pm
I need some help with a 91 Jetta, I recently purchased. It needs some wiring issues straightened out, among other things.
Number of posts : 3225
Re: help needed
Post by vwovalchild on Tue Jan 04, 2011 11:13 pm
Come on BKR...... you can do anything
Number of posts : 895
Re: help needed
Post by meinvw on Wed Jan 05, 2011 10:10 am
bakertim2 wrote:I need some help with a 91 Jetta, I recently purchased. It needs some wiring issues straightened out, among other things.
Just smack the dash occasionally, should fix most of them! Laughing I do not think I have ever owned a vw without some kind of wiring problems. The 80's-90's were the worst. What are the problems with it?
meinvw
Number of posts : 894
Re: help needed
Post by bakertim2 on Wed Jan 05, 2011 2:36 pm
It doesn't have power to the switch side of the starter and I cant hear the fuel pump running.
Re: help needed
Post by LungTube on Tue Jun 07, 2011 9:02 pm
Auto or manual? if its auto then neutral safety switch either way make sure your seat belt is connected(on). its got a switch in it and not clicked no start.
LungTube
Re: help needed
Post by vwtattooed on Tue Jun 07, 2011 9:21 pm
if it has the shoulder belt in the door, the car will not start unless the belt is hooked up! as stated also check neutral safety. most likely seat belt tho.....
Number of posts : 798
Re: help needed
