generator light
+4
atye
8 posters
Page 1 of 2 1, 2  Next
generator light Empty generator light
Post by buggin70 Fri Apr 29, 2011 12:27 am
it will come on if i rev high when it comes on ill hold in the clutch and it slowly goes down
then it wont be on for a while then it does the same thing
it will go for a while without it happening but other times it will be constant
do i need to replace the brushes? or is it the regulator or should i just get a 55 amp alt kit?
generator light Empty Re: generator light
Post by DOODLE BUGG Fri Apr 29, 2011 6:00 am
id get an alt kit an be done with it
http://bugglife.com
Post by callahan Fri Apr 29, 2011 8:08 am
just get an alt already
Number of posts : 1271
https://www.facebook.com/#!/profile.php?id=1030359664
Post by buggin70 Fri Apr 29, 2011 11:05 am
i read on the samba that some one replaced the regulator and the brushes and it fixed it
Post by buggin70 Fri Apr 29, 2011 12:54 pm
and what kit should i get?
http://www.kustom1warehouse.net/New_12_volt_alternator_conversion_kits_for_VW_p/al82xkit.htm
should i spurge for the bosch or is the one included good?
the price of the hit above is the same as a cb one
http://www.cbperformance.com/cataloglist.asp?Search=alternator+kit
which of these should i get?
Post by atye Fri Apr 29, 2011 2:16 pm
Slipping fan belt?
atye
atye
Number of posts : 259
Post by buggin70 Fri Apr 29, 2011 3:00 pm
the belt seems tight enough
Post by atye Fri Apr 29, 2011 3:16 pm
I just had to replace the voltage regulator on mine and the generator light never came on. I guess it was above the voltage needed to trip the warning light, but low enough not to keep the battery charged.
New regulator: $30 at AutoZone (Made in USA, too!)
Generator brushes: $5 online
Total install time: 10 minutes
atye
atye
Post by jmango Fri Apr 29, 2011 5:27 pm
I just bought the alternator from a parts store and did the under seat wiring per the illustrations on the Samba. Used the original pulley. Got an after market alternator stand. Used oe backing plate and strap. Someone here has probably posted the illustration too. I also upgraded the battery to a 48 series. Narry a problem again. This was on a 1970 Beetle 1500 12 volt system. Probably had $125 in the whole setup + $75 for the battery. $200 will get you rollin.
jmango
Number of posts : 24
Registration date : 2010-12-17
Post by buggin70 Sat Apr 30, 2011 12:47 am
my car is the same set up
but my throttle cable just broke so i have to fix that first now
Post by DOODLE BUGG Sun May 01, 2011 10:11 am
cable advance auto 3.99 so go ahead an order the alt while your there for a 75 bug with a internal regulater
http://bugglife.com
Post by buggin70 Sun May 01, 2011 11:21 am
i had a cable i was prepared
ill just get a kit from cb
Post by buggin70 Tue May 03, 2011 10:10 pm
so will 55amp be enough
when the gen worked i could do everything at the same time including wipers high beams my system and my cigarette lighter fan that i have
callahan is tellin me to get a bigger one though
Post by bumblebuggy Tue May 03, 2011 10:13 pm
Too much is almost always better than not enough. Cool
Post by buggin70 Tue May 03, 2011 10:21 pm
all of the cb kits come with 55 amp ones
all of the other kits come with china alternators and i dont wanna keep replacing them
Post by bumblebuggy Tue May 03, 2011 10:35 pm
I've had good luck with the china alts. The one in my bus is almost 15 years old and the one in my buggy is going on 3. Both 55amp. The bus lights do dim some when I hit the brakes...but that just lets me know my brake lights are working. I run a simple radio (no amps or anything) and, in the winter, I have a heated seat pad that plugs into my lighter. No issues. I think you'll be OK with a 55amp. It'll be better than a gen anyway.
Post by buggin70 Tue May 03, 2011 10:40 pm
so do you think the kit from kustom one will be fine?
Post by bumblebuggy Tue May 03, 2011 10:44 pm
As long as you don't have any big energy drawing plans in the future, I say go for it.
Post by buggin70 Tue May 03, 2011 10:49 pm
what about the problem of the fuel pumps and that carb spacer?
Post by DOODLE BUGG Wed May 04, 2011 10:03 am
it will still go with your stuff
http://bugglife.com
Post by buggin70 Wed May 04, 2011 10:23 am
ok if yall say so haha
i just saw on the samba that you need a differant fuel pump cause u wont be able to take this one out when the alt is in
Post by fluxcap Wed May 04, 2011 10:23 am
I was running a 34pict3 and when I switched to an alternator, the accelerator pump linkage just barely cleared, I mean it was REAL close. Fuel pump may be an issue. What type fuel pump do you have currently? You can run both styles with a generator, so it's possible you may already have the "alternator style" fuel pump on there already.
Post by buggin70 Wed May 04, 2011 10:26 am
let me take a pic and ill post it on here
Post by buggin70 Wed May 04, 2011 10:33 am
this is the one i have
i think i have a gen one
generator light 227478_2001685763152_1273824522_2305765_884384_n
Post by fluxcap Wed May 04, 2011 10:41 am
ehh, well that's one of the old style ones. I'm really not sure on those. I was thinking you likely just had one of the later mushroom style ones. Those are either "level" for a generator. (see how the mushroom top sits level)
generator light 454383
Or they are angled to allow room for the bigger alternator. (the one of the left is an old style, the one on the right is an angled alternator style, see how the mushroom top is tilted)
generator light 560211
