67 Rail Buggy
67 Rail Buggy
Before the restore...
Before Restore
After!
Before Restore
After!
macollins105- Dub Nut
- Number of posts : 104
Registration date : 2012-05-06
Buggy out of commission
I ran into a problem with the rail buggy today. I was running megaphones on the rail buggy but they were way too loud going down the road and I didn’t want to draw even more attention. I probably only put about 50 miles on the buggy without having baffles installed. I ordered baffles for the buggy and they came in last week. I spot welded them in and I hit the road. It was amazing how quiet it made the buggy. After about ten miles of driving, I started to hear a knocking sound coming from the rear of the vehicle. I would have never heard this sound if I wouldn’t have installed the four baffles. I noticed the knocking sound would start at a higher RPM right before I shifted to the next gear. The sound would go away as soon as I shifted and build back up until the next gear. When I would cruise in 4th gear running about 60mph the knocking was constant. If I pushed the clutch in running 60mph, the knocking would go away. I could also put the buggy in neutral and coast without hearing the knocking sound.
I was able to take the buggy to a guy that use to run a VW shop and he listened to it with a stethoscope. He determined the sound was not coming from the engine but somewhere in the transmission. He thought it might be the ring and pinion. I decided I would go ahead and pull the engine today so I could get to the swing arm transmission. Once I pulled the engine, I decided to take out the transmission plugs. Here are a couple photos of what I found...
The plug on the right has a few chunks of metal and was the plug closet to the engine.
Do any of you guys have any ideas on what the metal chunks belong to? In the next few days I plan on pulling the transmission from the buggy and breaking it down to rebuild it. I have three other swing arm transmission's that I will be able to use parts from. I wish I had a full day to work on it. I hate how this whole job thing gets in the way of my Volkswagen work!
Re: 67 Rail Buggy
I'd say the metal was from the inside of the trans... LOL.
Looks almost like gear teeth to me... Not good.
Re: 67 Rail Buggy
I thought I might also add that the buggy shifted into all the gears really smooth and never made any grinding sounds. I sure hope this will be a simple fix.....
Re: 67 Rail Buggy
I think I might have found the problem.....
Re: 67 Rail Buggy
Yepper,
Gear teeth. Seen it at work.
Up and Running
For the past week, I have been working hard at rebuilding a transmission for the buggy. Thanks to all the parts and pieces I had, I was able to use the gears out of the old transmission and ring, pinion and case from another. I was pleased to see that I had enough transmission parts to start building two more! I placed my newly rebuilt/ painted transmission into the buggy on Sunday and went ahead and put the motor back on late that night. I was able to try out the new transmission when I got home from work yesterday. The thing shifts smooth and all the knocking and winding noises went away. I was also very pleased to see that it stopped leaking transmission dope on my garage floor ...I got the buggy up to 80mph with more pedal left to go. This thing is a blast to drive and I love all the heads I turn it in.
Re: 67 Rail Buggy
1.21 gigawatts
vw57drvr- Complete Dub Addict
- Number of posts : 902
Uh-oh
Not a good day with the buggy...
Now I have a winter project!
Re: 67 Rail Buggy
Did the welds break on the rear assembly?
Trans mounts?
That sucks.
Looking at the tires though it appears that you got some use out of it this summer though.
Good luck with the repairs.
Trans mounts?
That sucks.
Re: 67 Rail Buggy
The factory welds broke on the rear assembly. I was driving on a bumpy road when it did it. Glad it didn't do that when I was driving on the street. I had a lot of fun with it this summer though... I going to really beef up the rear and build a nice motor cage this winter. In a way, the buggy breaking kind of works out..... I really wanted to take the buggy off insurance and put a 73 beetle on the road this winter. This made it real easy to pull the insurance..
» Turbo Mike's 952 Berrien Sand Rail
» 63 Buggy Budget Build
» Beetle Bug & Yellow Rail
» 19?? Mud Buggy
» early 60's handmade rail
» 19?? Mud Buggy
