ICAN'T GET THE CARB OFF
ICAN'T GET THE CARB OFF Empty ICAN'T GET THE CARB OFF
Post by islanddog on Thu Nov 06, 2008 3:54 pm
Ok guys I tried to take my carb off today but I cant get to the nut on the back side ...what is the trick do I need a special tool????
islanddog
Number of posts : 8
Registration date : 2008-10-26
ICAN'T GET THE CARB OFF Empty Re: ICAN'T GET THE CARB OFF
Post by 39coupe on Thu Nov 06, 2008 4:20 pm
I've taken mine off several times with a normal open end wrench. There is not much room to move it. I usually get it broke loose with the open end wrench and then finish it with my finger tips, but I have small hands.
39coupe
39coupe
Number of posts : 455
Post by meye5278 on Fri Nov 07, 2008 4:03 pm
Its easier tio take the manifold off then the carb i found that out when i had too take my generator off
meye5278
Number of posts : 2
Registration date : 2008-08-22
Post by daltondragger73 on Fri Nov 07, 2008 4:12 pm
The wrench i use to take the carb off is cut in half, gives u a lil more room to turn it!
Number of posts : 334
