Drop extensions
Drop extensions
Figured I would post these up. --->Drop Extensions
Basically you can lower your car with a bolt on part and still retain full suspension, no cutting of springplates!
Re: Drop extensions
I've been looking at a beetle set to lower the rear of my '65 but am uncomfortable cutting the stock shock mounts off. I have never lowered a bug before and I know you have Bryce, what are your thoughts on doing this vs just dropping a click the old fashioned way.
Re: Drop extensions
If you are going just one click then go one click on the torsion. If you are going lower then use this with adjustments on the torsions. I do like the idea of these and I have an extra set of axle tubes so cut away!
» bay drop spindles
» Bugeyed VW Parts
» My Late 71 camper! drop zone
» Installing drop spindles in the front
» 1st engine drop sanity check - done! (with a few pics)
» Bugeyed VW Parts
