My Gas Tank is a TACO...
+3
fearthefat138
buggin58
68bugkid
7 posters
so heres the story....
went to the bank friday to put in my check. i come outside and my gas door is open, cap missing. so that really pissed me off. i drive it capless to autozone and wow, they have ONE cap left that will fit a 68. 5 bucks and its mine, im happy lol.
fast forward to tonight...
driving down the road, i hear a loud PLUMP in the trunk and the car almost immediatly dies. i coasted off the road, and looked inside it. my gas tank is folded in at both front corners. undo the gas cap and POP it shoots out and kinda hits me in the stomache lol. apparently my awesome cheap autozone cap doesnt have a breather on it. so my gas tank imploded itself. i need a new tank, sending unit (probably) and definately an oem 68 cap. THANKS A**HOLE THAT STOLE MY CAP, you wrecked my car.
kyle came to the rescue and got me a red jug of gas, and i drove it hope capless (again).
YAY...
YAY...
68bugkid- Dub Noob
- Number of posts : 59
Registration date : 2009-07-20
Re: My Gas Tank is a TACO...
you know i got ur back like cyropract lol
buggin58- Dub Nut
- Number of posts : 123
Registration date : 2009-07-15
i got a tank you can have drive to cartersville and get it heres my number 7703099981 it has a sending unit and rubber neck but i dont have a cap
fearthefat138- Dub Nut
- Number of posts : 275
if you go to cartersville to get that tank, you can stop by herrells and get a real cap.
59suicide- Dub Crazy
- Number of posts : 552
if hes in dallas im the wrong direction from herrells
Well look on the bright side...............atleast you know you have a good strong fuel pump.
fearthefat138 wrote:if hes in dallas im the wrong direction from herrells
I was thinking Carrollton
Just take a compressor and blow it back up.
If it's a '68 the tank should also have a vent line and the only way it should've imploded like that is if that line is blocked. Make sure you clear you line before you attatch it to the new tank or you might run into the same problem again unless you insure the cap is vented.
the numb nuts who had it befor him capped that
i took the cap off for him
buggin58- Dub Nut
X2. Since that cap has such a good seal, drill out the center and bolt an air fitting through it and pop that sucker back out. I would correct the vent while your at is.bumblebuggy wrote:Just take a compressor and blow it back up.
Lol, not so fast numb nuts. The vent line is the clear tube hooked to the gas filler tube. You uncapped some nipple on the entire other side of the tank...buggin58 wrote:the numb nuts who had it befor him capped that
Lol :]
68bugkid- Dub Noob
68bugkid wrote:Lol, not so fast numb nuts. The vent line is the clear tube hooked to the gas filler tube. You uncapped some nipple on the entire other side of the tank...buggin58 wrote:the numb nuts who had it befor him capped that
Lol :]
Screw the cap, shove a rag in there and call it good, the rag will let the tank vent into the atmosphere.
dan
that other thing was an emergency vent
that should have never been capped anyway
buggin58- Dub Nut
thanks fearthefat for the gas tanks, it works perfectly
68bugkid- Dub Noob
» Taco Buggy -new ATL "food truck"
» gas tank help?
» 66 BUS Hesus
» Rust removal by electrolysis (revisited) with detailed photos/info
» gas tank help?
» 66 BUS Hesus
