empi carb???
empi carb??? Empty empi carb???
Post by daltondragger73 Sun Apr 10, 2011 10:46 pm
so got the new bus has a 1776 also the guy threw me a EMPI HPMX 40 curious if anybody has experiance with this carb would it wake up the motor a lil bit or not even worth putting it on I forget what it has on it now but ill look tommorow
Number of posts : 334
empi carb??? Empty Re: empi carb???
Post by bumblebuggy Sun Apr 10, 2011 10:52 pm
Unless he threw you the manifold and all the other parts, you might just want to run what it came with.
Post by daltondragger73 Sun Apr 10, 2011 11:00 pm
bumblebuggy wrote:Unless he threw you the manifold and all the other parts, you might just want to run what it came with.
OHH yeah!! he gave me the full manifold with lines drilled into it and connectors for the brake vaccum, Ive heard alot of bad about Empi so was just curious as to if its a good set up
Post by bumblebuggy Sun Apr 10, 2011 11:03 pm
Worst that could happen is you put it on and it runs like crap. Give it a shot!
Post by DOODLE BUGG Mon Apr 11, 2011 2:08 pm
the empi icts are junk the hpmx are good carbs but id look for a good used dell an have no fear of runing like crap
http://bugglife.com
