the Ratty Fatty
+13
mtownbeetle70
PeeWeeMan91
Rusty62
LB Bedwell
17 posters
Page 1 of 2 1, 2  Next
the Ratty Fatty Empty the Ratty Fatty
Post by callahan Wed Feb 09, 2011 10:36 pm
just got home with a new project its a 71 fatty
overall it is in great shape, super solid pans with undercoating still on it there is basically no rust on the car and other than passenger rear fender it is super straight, cheesy dark red respray, complete clean black interior sans the headliner. looking for some 65 or 66 black lowbacks if anyone knows of any please let me know. other than the bumpers its got all its parts, and should be a pretty straight forward put her back together and roll it project. also got a good sp engine for it. gonna start digging into it tomorrow
here's some stuff i need lmk if you can hook me up:
bumpers, running boards, body trim, plastic vents behind windows, black low back seats, dual mount antenna, more will be added as i get more into it
here's what i'm thinking about right now not really sure if i'm going to try to paint it yet
the Ratty Fatty Ratty_10
on with the pics
the Ratty Fatty 100_1110
the Ratty Fatty 100_1111
the Ratty Fatty 100_1112
the Ratty Fatty 100_1113
the Ratty Fatty 100_1114
the Ratty Fatty 100_1115
the Ratty Fatty 100_1116
Number of posts : 1271
https://www.facebook.com/#!/profile.php?id=1030359664
the Ratty Fatty Empty Re: the Ratty Fatty
Post by callahan Wed Feb 09, 2011 10:45 pm
looking for some adjustable struts too
Post by Goped406 Thu Feb 10, 2011 12:12 am
http://toplineparts.com/
They have good parts, i used them when i lowered my old 71 sb. Good quality
Number of posts : 215
Registration date : 2008-12-06
Post by Attorney Isaiah Loophole Thu Feb 10, 2011 5:56 am
Nice clean start. Should be fun!
Post by Attorney Isaiah Loophole Thu Feb 10, 2011 5:59 am
Unless you plan on changing the seat tracks on the pan or using the bottoms from the seats that are in there with the backs of the low backs then low backs wont fit.....you could always cut the high backs down into lowbacks though
Post by vwtattooed Thu Feb 10, 2011 7:34 am
Attorney Isaiah Loophole wrote:Unless you plan on changing the seat tracks on the pan or using the bottoms from the seats that are in there with the backs of the low backs then low backs wont fit.....you could always cut the high backs down into lowbacks though
that's what i was thinking...i have cut down a couple of sets of high backs,VW made it easy to turn these atrocities into some cool seats!! you can also run newer model VWseats, rabbit, jetta, etc.. early rabbit seats are pretty much direct fit. if you get a set with removable headrest...presto...lowbacks. can't wait to see it done...i like fat chicks!
Number of posts : 798
Post by callahan Thu Feb 10, 2011 11:11 am
i was thinking about just changing the seat backs, i thought about cutting them down too but i'd rather swap the backs before i hack up the nice ones that are in there
Post by zabo Thu Feb 10, 2011 11:33 am
yep id go with some rabbit seats...
Post by LB Bedwell Thu Feb 10, 2011 1:54 pm
i have some plastic vents
LB Bedwell
LB Bedwell
Number of posts : 540
Post by callahan Thu Feb 10, 2011 2:11 pm
cool i should be at tims next weekend for the body swap business
Post by ASBug Thu Feb 10, 2011 2:48 pm
While you are there, ask Tim about off set wheels that will fit with your lowered front end.
I had to run the T-backs, in that the Rivis and the Empi 8's had too much offset to run on the lowered front. I have the Empi set up all the way down. I am running 145 65 15's.
I also did a Disc brake conversion and I think it moved the wheels out a little.
Post by ASBug Thu Feb 10, 2011 2:50 pm
Is that a bus muffler?
And 2 jacks - one for each side!
Post by DiggerD Thu Feb 10, 2011 4:54 pm
I have a rear bumper with brackets, and maybe some trim pieces. Good to see another flat window super on here! Cool
Post by DiggerD Thu Feb 10, 2011 4:56 pm
ASBug wrote:While you are there, ask Tim about off set wheels that will fit with your lowered front end.
I'm running some chrome mangles with 145's on mine and it probably couldn't get much lower in the front!! Twisted Evil
Post by vwtattooed Thu Feb 10, 2011 7:08 pm
the Ratty Fatty Newpaint the super in this pic sits @ 1" off the ground, it's running 165/45/15 on chrome mangels and was lowered by modifying the stock strut housing and running a Rabbit strut insert! like $30-$40 each for strut inserts and a little welding and it rides like a cadilac for a car this low.
Post by callahan Thu Feb 10, 2011 9:24 pm
yes the sp engine is out of a bus, and yep two jacks in the car along with a pile of other random stuff including some odd off road exhaust set up, and the golden nugget of the whole deal. . . an early 356 front brake set up, drum spindle and everything that should provide some nice funding for this project.
got the fender back on and all of the lights hooked back up and working gonna clean her out good tomorrow and take some more pics
and i think with stock wheels and 145/65s i should be able to go pretty low with no real issues, i've still got a while before i have to worry about that
Post by Rusty62 Fri Feb 11, 2011 5:13 am
Dude thats a pretty sick ride!Keep the pics coming. Cool
Rusty62
Rusty62
Number of posts : 105
Registration date : 2009-02-26
Post by callahan Tue Apr 26, 2011 5:45 pm
slow progress on the fatty
engine all together and ready to go in but its binding up on something in the tranny and won't budge its only got another inch to go but idk what the deal is, its got late model flywheel, clutch, pressure plate, and correct t/o bearing the only thing i can think of is the clutch hanging up on the sleeve that sits around the input shaft
but still need a passenger side running board, the little plastic vents behind the quater windows, and the spacer that sits inside the outer grease seal between the bearing and brake drum on the rear end
and she'll be officially for sale as soon as she's up and running so if you like dirty ol fat chicks hit me up
the Ratty Fatty 100_1314
the Ratty Fatty 100_1315
Post by callahan Tue Apr 26, 2011 8:34 pm
engine is in! sort through the mess of wires tomorrow and hopefully fire it up
turned out the surface rust on the imput shaft was to blame so i realligned the clutch sanded down the input shaft threw a bit of grease on it and showed that engine who's boss
Post by PeeWeeMan91 Wed Apr 27, 2011 8:28 am
i want mine just a little bit above that mar like 4 in off the ground so i can get the tow bar on it if it breaks down
PeeWeeMan91
PeeWeeMan91
Number of posts : 567
Post by drewBAKER Wed Apr 27, 2011 6:23 pm
PeeWeeMan91 wrote:i want mine just a little bit above that mar like 4 in off the ground so i can get the tow bar on it if it breaks down
or so someone else can get a tow bar on it and steal it. which is where slammed cars come in handy. Smile
Number of posts : 707
Post by callahan Wed Apr 27, 2011 6:40 pm
more progress today wiring sorted through and hooked up the correct way
started taking off some of the red paint off, OG yellow underneath looks pretty good gonna get some easy off and keep at it until it sells
still need bits and pieces listed above if you can help me out please lmk asap
the Ratty Fatty 100_1316
the Ratty Fatty 100_1317
4x4 baby
the Ratty Fatty 100_1318
not a lick of rust
the Ratty Fatty 100_1319
Post by callahan Mon May 02, 2011 7:03 pm
finished up the fatty today
painted wheels, bolted up front bumper fixed leaking tank to tunnel gas line and it fired right up, runs nice but with the 1200 and irs this thing is a slug! lol wouldn't be bad around town but anything other than that would just be annoying, need to button up a few more little things like heater tubes and stuff but other than that i'm done with this thing
1500 for anyone who gets at me through GA dubs
the Ratty Fatty 100_1320
the Ratty Fatty 100_1321
the Ratty Fatty 100_1322
Post by mtownbeetle70 Mon May 02, 2011 8:42 pm
dude how much you want for the roof rack
mtownbeetle70
mtownbeetle70
Number of posts : 166
Registration date : 2010-10-23
Post by callahan Mon May 02, 2011 9:56 pm
thats jolene's rack it does not go with the fatty
jolene is just saving some mpg's for a little while
