1961 Gulf Blue Ragtop
Page 1 of 4 1, 2, 3, 4  Next
1961 Gulf Blue Ragtop  Empty 1961 Gulf Blue Ragtop
Post by Attorney Isaiah Loophole on Fri Jul 17, 2015 12:26 am
I did some trading with Joel and picked this car up.  I have always liked it even before it had the rag grafted in.  Anyway I have already started making a few changes.  First the adjustable plates came off and a set of 4" drop plates went on.  Then on to the front which I am still working on.  I am painting and building a set of drop spindles for the car so I can gain some suspension back.  Hope to have them on this weekend.  I also wanted to run some kind of black and polished/silver wheels.  I was going to go with steel sprint stars but ended up changing my mind last minute.  Next will be an interior overhaul and then some body work and fresh gulf blue paint
Basically how I got it from Joel....
1961 Gulf Blue Ragtop  0d4ld9_YOHOTBgQBw8ftX1ub5aPO3ElTflFJnmQ8oKE=w890-h667-no
1961 Gulf Blue Ragtop  Xew9on1NzqlbYlcqUOfEOVbEn7V9pEaZqGZ0Ww1kIlQ=w501-h667-no
1961 Gulf Blue Ragtop  RCqFQexSOrbPf1E1BXaNdXsIkb3P9R6C8Dj9IWB9U5U=w501-h667-no
1961 Gulf Blue Ragtop  AkM_1Nqjj7XgZhQvm-OOiL-Qgu_kwLLnhYOPcif65wU=w890-h667-no
My boy, Colby!
1961 Gulf Blue Ragtop  80csE2nQvl1WjEh0UKJWhkph8nQvZeKRHW9Gm9DmDcc=w1001-h667-no
New wheels!
1961 Gulf Blue Ragtop  WQCfDPhmmA14KgSDlybvcddTJ65U7Y6RvJVawA9U1gI=w890-h667-no
1961 Gulf Blue Ragtop  YBkDzQS6o8Im2JW4dem6uxCKF87ibOk7TF3MFwVnZhg=w501-h667-no
Last edited by Attorney Isaiah Loophole on Fri Jul 17, 2015 10:26 am; edited 1 time in total
1961 Gulf Blue Ragtop  Empty Re: 1961 Gulf Blue Ragtop
Post by zabo on Fri Jul 17, 2015 9:03 am
Attorney Isaiah Loophole wrote:
My boy, Colby!
nice man!!
Post by Attorney Isaiah Loophole on Fri Jul 17, 2015 9:28 am
zabo wrote:nice man!!
Thanks!
Post by Attorney Isaiah Loophole on Fri Jul 17, 2015 2:59 pm
New all metal parcel tray from Shorty's Customs!
1961 Gulf Blue Ragtop  Puqsi2b-tjXuUDmxjin2FIvFsn7AY1L-pCRbIce016w=w890-h667-no
1961 Gulf Blue Ragtop  THV0nYVVJM3v73wBDPdnMhxaHCRJoP-jMBqttukyNVE=w890-h667-no
Post by Attorney Isaiah Loophole on Fri Jul 17, 2015 3:43 pm
Found some old pictures of Old Blue before the ragtop graft and then a couple after it was installed.  All the pictures are from 2008.
1961 Gulf Blue Ragtop  OegwvDgQgOfA_NBQINapEC0XiGSq2ojnfOqkkicMgQU=w895-h667-no
1961 Gulf Blue Ragtop  RrQcfXGCEMtEh5McP6Tk1wvOssYSdhd5FSigT_mTbd0=w895-h667-no
1961 Gulf Blue Ragtop  MRHnJpNdBMfqFRE6aWkv1uUjZuDcz9qrvGtVvRmZxxw=w895-h667-no
1961 Gulf Blue Ragtop  F67it5Sd5HP_19bjAH2yy9CLX659_mgtiUr5atVPJQ0=w895-h667-no
1961 Gulf Blue Ragtop  M-285AbcnLqoWgyHfM61omJmTqj9bW_yMhrcMYSXIts=w895-h667-no
1961 Gulf Blue Ragtop  Jjz9Nog988Jf3H6sMlb9XSKvQdGmKcTnf1xLdu8rmbE=w895-h667-no
Post by Dake on Sat Jul 18, 2015 9:39 am
Man that a great looking car. Congrats on the new Baby!
Number of posts : 145
Post by Attorney Isaiah Loophole on Sat Jul 18, 2015 10:23 am
Dake wrote:Man that a great looking car. Congrats on the new Baby!
Thanks!
Post by pwmcguire on Sat Jul 18, 2015 5:42 pm
Congratulations on the new baby and his first VW.
Number of posts : 787
Post by Attorney Isaiah Loophole on Sat Jul 18, 2015 10:30 pm
pwmcguire wrote:Congratulations on the new baby and his first VW.
Thanks Pat!
Today I got the carriers cleaned, blasted, and painted along with the drop spindles. Installed new king pins and link pins and got them on the car. I need to do a little work on the bottom adjuster as it is bent pretty good so the car won't raise back up to where it was before I installed the spindles. I think its sitting about an inch lower now with no one in the car. I may have to pull the beam and put in a new adjuster.....
1961 Gulf Blue Ragtop  XNKcQ10VlAwNEQqdXLIPGYWas82RjxsDIWW9HHcxTsA=w1012-h667-no
Post by drvr8 on Sun Jul 19, 2015 1:49 pm
Looks good buddy... you're making good progress... does make me a little sad... but I know that he has a good home... and I got an awesome car and a great bus outta the deal!
Number of posts : 127
Post by Attorney Isaiah Loophole on Sun Jul 19, 2015 5:20 pm
Since the car is a 61 it doesn't have a gas gauge and should have a reserve lever.  It came with a fuel lever extension but no lever and after looking under the 62 and later tank I saw that it had no reserve petcock.  So today I pulled the gas tank and removed the 62 and later fuel outlet and installed a reserve petcock and lever.  I also removed the fuel gauge block off and installed a 68 and later electric sending unit for when I put in the 68 speedometer.  The car came with a fuel lever extension so I put it on as well.  Then I started pulling the front seats and the rubber mats and did some vacuuming.  Then I installed new front and rear black rubbers mats.
1961 Gulf Blue Ragtop  KbDaDPtZrx7BFyFmqav8YTXrJEH6Kw72r7tZF3rLyKs=w890-h667-no
1961 Gulf Blue Ragtop  5zL8MfouS5PTfeEWWLC2fVTBZDM29BppS6aTVdPJXrU=w890-h667-no
1961 Gulf Blue Ragtop  NKZwiVnshz2CfECk1ofkvk32VJXbgxRUJ-DaiKcKi8o=w890-h667-no
1961 Gulf Blue Ragtop  0vRAPZv_if9ZSGObJNlAkux2K5lNWGVSos2AM2vPgVg=w890-h667-no
Post by drvr8 on Sun Jul 19, 2015 5:30 pm
Looking good buddy!
Post by Attorney Isaiah Loophole on Sun Jul 19, 2015 5:31 pm
drvr8 wrote:Looking good buddy!
Thanks dude!
Post by Attorney Isaiah Loophole on Mon Jul 20, 2015 4:52 pm
Decided to go ahead and clean up the 68 speedometer I had in the garage.  I had to pull apart a second speedometer to get a good clean glass.  While apart I cleaned the glass, outer chrome, inner ring and housing  I also cleaned off the old grease and lubed all the gears.  Before putting it back together I zeroed out the odometer.  I didn't have anything to use for gel material so I just left them blank.   I did replace the old metal fuel gauge vibrator with a plastic encased one.  I should have taken a before picture but I didn't.
After cleanup
1961 Gulf Blue Ragtop  W6TG0C9kJvspYsOvwU-B3aJ_3LjzlsOzm2Prwv-xmgI=w1012-h667-no
Installed and gas gauge working!
1961 Gulf Blue Ragtop  0v8s4fozuiA9xVZTIs14-DnuLR57StGTOf7z70jqLM8=w1012-h667-no
Post by BKiller on Mon Jul 20, 2015 9:24 pm
Looks great Bryce.
Number of posts : 687
Post by pwmcguire on Mon Jul 20, 2015 9:32 pm
Colored file folder tabs sanded with 1000 grit sandpaper works great, put the shiny side out.
Attorney Isaiah Loophole wrote:Decided to go ahead and clean up the 68 speedometer I had in the garage.  I had to pull apart a second speedometer to get a good clean glass.  While apart I cleaned the glass, outer chrome, inner ring and housing  I also cleaned off the old grease and lubed all the gears.  Before putting it back together I zeroed out the odometer.  I didn't have anything to use for gel material so I just left them blank.   I did replace the old metal fuel gauge vibrator with a plastic encased one.  I should have taken a before picture but I didn't.
After cleanup
Post by Attorney Isaiah Loophole on Tue Jul 21, 2015 1:04 am
pwmcguire wrote:Colored file folder tabs sanded with 1000 grit sandpaper works great, put the shiny side out.
Yeah I had read that on the samba but I couldn't find any here at the house. Did you double yours up too?
Post by panic_fan on Tue Jul 21, 2015 3:17 pm
Very nice. Awesome pic of the newbie. Smile
Number of posts : 410
Post by fluxcap on Tue Jul 21, 2015 3:48 pm
I double them up when using the file tabs. Looks great man, you must be a wizard to get that fuel gauge working. That dang thing gave me so many problems when I tried that set-up, lol.
Post by pwmcguire on Tue Jul 21, 2015 10:24 pm
No, single layer, green and red work great. Blue sucks, If you need blue for the high beam on a 70's speedometer
Post by Attorney Isaiah Loophole on Tue Jul 21, 2015 11:36 pm
fluxcap wrote: Looks great man, you must be a wizard to get that fuel gauge working. That dang thing gave me so many problems when I tried that set-up, lol.
We will see how long it works. Good used gauge, new vibrator and new sending unit....
pwmcguire wrote:No, single layer, green and red work great. Blue sucks, If you need blue for the high beam on a 70's speedometer
Sounds good! My blue is actually in pretty good shape.
Post by Attorney Isaiah Loophole on Wed Sep 02, 2015 3:59 pm
Downtown Griffin
1961 Gulf Blue Ragtop  9ZpvbrzH_4jUqFUU4SxwDFsBukKxohc_eA0Pyl7UoCQ=w401-h667-no
1961 Gulf Blue Ragtop  SzbeHMy7KRjzf2WJhfGr2R2Nd7UzeBZuX2hGm16NjUI=w1112-h667-no
Post by vw57drvr on Wed Sep 02, 2015 4:25 pm
Im pretty partial to those wheels. Looks good.
Post by Attorney Isaiah Loophole on Wed Sep 02, 2015 4:41 pm
vw57drvr wrote:Im pretty partial to those wheels. Looks good.
Yeah I have always liked them even before they repopped them. I had narrowed my wheels choices down to either steel sprint stars or cosmics. I loved how they look on your car but I was still leaning towards the sprints but they were out of stock. I couldn't get an answer to how long they were going to be out of stock so the decision was easy!
Post by vw57drvr on Thu Sep 03, 2015 4:16 pm
The offset if really good on these. Keeps the wheels tucked further than a BRM for example.
