ENGINE COMPARTMENT RUBBER
i'm getting ready to do a couple engine swaps and was wondering how hard it is to change the rubber around the engine tins and breast plate. do you do it before or after the engine install.
Thanks Dubbers
Thanks Dubbers
Dodgerdog- Dub Noob
- Number of posts : 54
Re: ENGINE COMPARTMENT RUBBER
before with engine out
ggaagg57- Dub Nut
- Number of posts : 484
And it kinda sucks to do! I have to do mine in my bug soon. If the channel the seal slides in is in good shape, it's not too bad, but usually the channels are rotted and banged up and it's hard to slide the new seal in.
x 1,000,000ggaagg57 wrote:before with engine out
just take the time to go around and open up the track for the seal to slide into
ggaagg57- Dub Nut
actually got one of them done, wasn't that bad. the worst part was going around the corners. I just pressed the rubber into the bottom part of the channel and used a wide bladed screw driver to press the rubber into the top groove. now if I could just get more pedal on my brakes
Dodgerdog- Dub Noob
» Engine Compartment Restoration
» Breech In Engine Compartment
» Oil spray in the engine compartment
» rubber cam plug leaking ?
» Rubber boot (bellows) at front end of transmission?
