raising rear end (the car)
raising rear end (the car) Empty raising rear end (the car)
Post by Dodgerdog on Thu Jan 08, 2015 10:05 am
I'd like to raise the rear end of my 72 sedan an inch or two and don't really want to mess with the torsion bar, really I'm afraid to mess with the t bar. I was wondering if they sell those type shocks with the helper springs for vw's or how hard is it to drop the front end a couple inchs
Dodgerdog
Dodgerdog
Number of posts : 54
raising rear end (the car) Empty Re: raising rear end (the car)
Post by Attorney Isaiah Loophole on Thu Jan 08, 2015 11:16 am
I know empi sells those coil over shocks and they will lift the car but usually they ride pretty stiff.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4075
raising rear end (the car) ACC-C10-4075-2
Re-indexing the springplates is not that hard and after turning so many splines each way you get back to where you started.  Just mark the housing and springplate in the unloaded position to know where you started.
As far as lowering the front if it is a regular beetle you could install 2.5" drop spindles or install adjusters in the beam.  If it is a Super beetle you could put on lowered springs or buy adjustable struts.
Post by Dodgerdog on Thu Jan 08, 2015 2:16 pm
thanks for the info
Dodgerdog
Dodgerdog
Post by Dodgerdog on Thu Jan 08, 2015 2:21 pm
the vert I have I think the torsion bars were adjusted before I bought it but I have never seen it done and just a little scared of them, might try utube
Dodgerdog
Dodgerdog
Post by ASBug on Thu Jan 08, 2015 2:32 pm
Just be aware that those shocks will ride VERY stiff.
I have a set on the Ghia Vert because of the natural sag in the rear end and to even it up (1.5" on one side and 2" on the other).
If you run over any thing you will get Jarred. They are super stiff.
Post by fluxcap on Thu Jan 08, 2015 3:27 pm
Springplates aren't really hard to adjust, but will take some time doing them your first go around. Best to have new bushings already in hand before starting. The first time I did mine, I pulled everything apart and a few of the old bushings were nothing but dust, so I had to wait on new ones. You may not need them, but they don't cost much either so it won't hurt to go on and buy them.
I remember there was a YouTube video of somebody doing the springplates on a squareback a while back that was helpful the first time I did mine.
Post by ASBug on Thu Jan 08, 2015 4:07 pm
On my old '71 RHD 1302 I had as well as my current '69 Ghia I have dual arms on each side. They are a little different to get off, but the concept is easy when you have looked at the Youtube videos. I like having a small roll around floor jack to take the load off when you are pulling the arms out, then you can relieve the pressure gradually.
X2 on the new busings, the ones in the Ghia are deteriorated.
