magura fuel sending unit for type 1
I'm not sure if you know but this is an OG Magura fuel sending unit. There is no rubber boot on the pivot arm to leak, just a set screw. Unscrew the set screw and pull the arm to the float out. You can replace the o ring with a
6mm x 10mm x 2mm o ring from the auto parts store. Clean the arm and the pivot shaft and re grease it. These are much better than the kind with the rubber boot and any aftermarket version.
- Number of posts : 787
» Type 4 Fuel Injection issue
» Stereo's in the VW
» type 3 brakes on a type one
