76 Westy- which accessories connect to fuse holder #9?
Looking at my electrical system and ignition. The key was stuck in the ignition when we got the bus a couple weeks ago for one. We used penetrating oil on it and it came out finally and it matches all the locks. Yeah! So we ordered two keys from veedubkey.com site. If u know have your original key and you can read the key code he can cut you a key for $10. They had installed a Briggs and Stratton ignition to bypass the original key... So it's time to get the original ignition hooked back up. But it is a "mouse nest" up under the dash with wires going everywhere..When looking at the "block style" fuse holder designation list from ratwell.com, it just shows "accessory" for fuse holder #9. Is there a sub list for those accessories?
Rwflyboy- Dub Noob
- Number of posts : 56
Registration date : 2014-04-13
Re: 76 Westy- which accessories connect to fuse holder #9?
"accessories" is kind of a generic term meaning anything the PO needed power for. As such, there won't be a list. You may want to take the wiring diagram below to a printing shop and have it blown up and laminated. I forget where fuse 9 gets power from but the diagram will help you sort out the rats nest.
http://www.thesamba.com/vw/archives/info/wiring/baybus_76.jpg
Greg- Dub Nut
- Number of posts : 118
Thanks Greg. I think I will just start trying to trace wires from the fuse "box" back to where the PO's took them.... after I put on the missing cabinet latches/new sink pump etc in/re-key sliding door and some brake mainenance..... But thanks for the wiring scheme!!!
Rwflyboy- Dub Noob
