Fuses keep popping loose
Anyone have a solution for the old 8 amp fuses sometimes popping loose and breaking connection in the old boxes?
Was considering making a small modern style fuse panel to replace them, but would rather fix this right.
Just so you know, this is for a 1960 Beetle and mainly my driver side taillamp fuse coming out. It also appears to be seated well into the holder as well.
Any suggestions are greatly appreciated.
Murdock00- Dub Noob
- Number of posts : 53
Registration date : 2013-05-22
Re: Fuses keep popping loose
Electrical spray and tighten the tabs
vw57drvr- Complete Dub Addict
- Number of posts : 902
callahan wrote:Just fold the tabs on the fuse box in some so the fuses are tighter
Remove the fuse and push the tabs closer together
- Number of posts : 787
Will try that, just didn't want to accidentally break off one of the tabs.
Murdock00- Dub Noob
Even if you do snap the tab the box is available from several venders and in a pinch a inline can be spliced in if there's a need to keep it rollin . Is that the four fuse box ?
wagtag- Dub Noob
- Number of posts : 46
If you need an inline fuse. I make these.
http://www.thesamba.com/vw/classifieds/detail.php?id=1484940
They can be used anywhere. Just let me know.
Yeah its the four bus fuse panel, they never have seated right in there as well. Or at least I can't make them sit right in there.
Murdock00- Dub Noob
If its shot you can try Robertson automotive in Augusta . Darryl and Silke have a amazing inventory of hard to find parts , PM me if you need their phone number or go the internet route such as http://www.vwispwest.com/home.php .
wagtag- Dub Noob
Been to their shop before, but sadly have not had the time to try and fix this yet because of work.
Murdock00- Dub Noob
Working man blues, never time for the things you love. you spend your time making a living
wagtag- Dub Noob
» A place to buy fuses in Atlanta?
» Popping your bubble
» Carb popping and skipping
» Any one on here "loose" as 66 Vert?
» help me before i loose my marbles!!!
