Brake issue
+2
New 67 owner
6 posters
Brake issue
Brakes went out so I put on a new master cylinder , adjusted and bleed the brakes and still no pedal. Do I need to adjust the rod off the pedal? Any help
New 67 owner- Dub Noob
- Number of posts : 50
Registration date : 2013-11-24
Re: Brake issue
Adjust the brakes on all 4 wheels out, tight against the drums. Then bleed. Then back them off. Hopefully this works. I personally use a vacuum brake bleeder from harbor freight. They say it shouldn't work, but it has for me. Don't mess with the rod.
- Number of posts : 787
Re: Brake issue
Not normally how much free play is in your.pedal. should be half to 3/4 inch pedal free play before rod hits master piston. Check for leaks in your system Esp the rear brake line running on the floor. Bleed brake light switch also.
Re: Brake issue
I did replace the line to the rear also
Re: Brake issue
Dig deeper
Re: Brake issue
I wouldnt touch the push rod. Sometimes these new master cylinders can be tough to get to bleed. That is if it isnt defective.
vw57drvr- Complete Dub Addict
- Number of posts : 902
Re: Brake issue
Watch your pressure on those bleeders some will blow seals.
Re: Brake issue
What had happened a lady pulled out in front of me I locked the brakes up. Then the next time I tried to stop no brakes. I've put on a new master cyl., line going to rear, bleed every thing, adjusted the brakes and still no brakes if I can't figure this out there will be a 67 bug going cheap
Re: Brake issue
ive had 2 defective master cyls in a row! installed one, no dice, installed.another same thing, installed the third one bam it fixed it. i was having the same problem.
60andslow- Dub Crazy
- Number of posts : 531
Re: Brake issue
I got it from oriley auto
Re: Brake issue
Stay away from those style parts stores for old school Vw stuff not worth the headache.
Re: Brake issue
Get an OE brand one. It's made in china but it's the best for the money. The German one is triple the cost.
Re: Brake issue
I've decided to replace everything in the brake system but the pedel and backing plates this will fix my brake problem
