Advice on Carpet
Advice on Carpet  Empty Advice on Carpet
Post by mrfeather Mon Apr 14, 2014 11:43 pm
Here is my issue my 56 is sitting on a 70 pan with early set tracks welded in so that I can use the low back sets. I know that the heater vents on the 56  is all the way to the fire wall on the car. Knowing that I assume that I need to use a 56 carpet set but need to know that the carpet would fit the pan.
mrfeather
mrfeather
Number of posts : 176
Advice on Carpet  Empty Re: Advice on Carpet
Post by Gabass Tue Apr 15, 2014 8:07 am
Probably 56 carpet on the heater channels, luggage compartment, and under the dash if you're doing that; and 70 carpet directly on the pan and tunnel.
Gabass
Gabass
Number of posts : 350
https://www.facebook.com/NorthGeorgiaSpeedometer?fref=ts
Post by bakertim2 Tue Apr 15, 2014 8:22 am
Really, the only differences are the location of the shifter and the heat controls on the pan. The later pan shifter location is further rearward and the heat controls are located on the sides of the parking brake handle instead of the knob by the shifter.
