Advice on Carpet
Advice on Carpet
Here is my issue my 56 is sitting on a 70 pan with early set tracks welded in so that I can use the low back sets. I know that the heater vents on the 56 is all the way to the fire wall on the car. Knowing that I assume that I need to use a 56 carpet set but need to know that the carpet would fit the pan.
mrfeather- Dub Nut
- Number of posts : 176
Re: Advice on Carpet
Probably 56 carpet on the heater channels, luggage compartment, and under the dash if you're doing that; and 70 carpet directly on the pan and tunnel.
Really, the only differences are the location of the shifter and the heat controls on the pan. The later pan shifter location is further rearward and the heat controls are located on the sides of the parking brake handle instead of the knob by the shifter.
» Interior Carpet for our 73
» Tmi rear carpet kit....
» Bus Seat Advice
» need advice please
» New guy, just got a bug, need advice
» Bus Seat Advice
