Slamming the square.
+3
Gabass
Slim4life
7 posters
I'm trying to figure out what tires I should get for the square. I already have 135's and I rub(bad). I'm looking at 165/45/15 because I need to get the front down but I don't know how they are going to look on stock 15x4. So I looked at 145 65 15 but they don't seem small enough..... please help. I need to order them soon. Pictures would help. Thanks
Slim4life- Dub Noob
- Number of posts : 38
Registration date : 2013-09-28
Re: Slamming the square.
Sounds like you need a custom built beam
No money for that right now
Slim4life- Dub Noob
Im not running temp tires because I drive this thing all the time with my wife. And don't want anything happening to her.
Slim4life- Dub Noob
I think the 165 will be a lower profile, but will be wider. You should get an extra inch of clearance between the top of tire and edge of wheel well, however, since the tires are a little bit wider it'll also be around 15mm closer to sitting under the fender edge.
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile
165/45-15 2.9in 10.4in 20.8in 65.5in 967
135/80-15 4.3in 11.8in 23.5in 73.8in 858
Now does anyone have pictures of them on a square
Slim4life- Dub Noob
The second result isn't on a square but it does show how big they are.
http://www.google.com/search?safe=active&hl=en&site=imghp&tbm=isch&source=hp&biw=1366&bih=653&q=squareback+with+165%2F45%2F15&oq=squareback+with+165%2F45%2F15&gs_l=img.3...2968.16327.0.16559.25.10.0.15.3.1.423.1115.8j1j4-1.10.0....0...1ac.1.38.img..15.10.563.liDBk8F0izw#facrc=_&imgdii=_&imgrc=icDqXUn9W51w_M%253A%3BRYKYcgy_ygQaSM%3Bhttp%253A%252F%252Fimg.photobucket.com%252Falbums%252Fv391%252Fmejiacne%252F63%252520Ragtop%252FSlammed%252520Ragtop%252FP1010671.jpg%3Bhttp%253A%252F%252Fwww.thesamba.com%252Fvw%252Fforum%252Fviewtopic.php%253Ft%253D392082%2526start%253D20%3B1023%3B683
Ask Raymond his notch is low
this is not Raymond's notch, but one I found on the samba. (just look at the front end, and imagine a square back end)
http://www.thesamba.com/vw/forum/album_page.php?pic_id=409015
Description in link above says 165/45 up front and 205/70 in rear.
Tire like this doesn't stick out past the rim much so no problem there. I never use anything smaller than a 165/50/15
Wow, that is wide... On my Ghia the fender is erasing the word good year off the sidewall with 185 65 15's I wish the rear on the ghia didn't cut in...
This bug has 165/45R15s 0n the front
How wide are the wheels on the bug?
Slim4life- Dub Noob
5in. Maybe 5.5.
- Number of posts : 1416
They're 5.5"
