1st time distributor swap
1st time distributor swap Empty 1st time distributor swap
Post by ultralite on Tue Mar 11, 2014 7:46 pm
Trying to get ready for a road trip and decided to buy a new distributor and keep the old as a spare. From Bus Depot I ordered the Bosch with vacuum advance (svda?). Which I understand to be more "original". Anyway, I haven't done this before and I'm not seeing where a vacuum line would attach to the carburetor. So here's the current set up.
1st time distributor swap 5C05EF9B-DC5D-480A-8774-8F64A80B5D9D-970-000002569C18E4C1_zpsb6f75ac1
Here's the left side of the carburetor.
1st time distributor swap 3DBB8850-33D1-4002-BC90-8D9901ABAD81-970-0000025672CE983D_zpsa9bd373f
Is that where it would go? I'm guessing you have to unscrew that piece and pop out the gold plug in the middle?
1st time distributor swap 77F59B65-24E9-4784-B7B0-E5F99DE12243-970-00000257330209ED_zps9602652c
ultralite
Number of posts : 181
1st time distributor swap Empty Re: 1st time distributor swap
Post by ultralite on Tue Mar 11, 2014 7:51 pm
I have both the Bentley and Muir books and I've searched the site first. Oh wait a sec, I forgot I'm not on Samba  Laughing
Here's the new distributor: 1st time distributor swap 8F28D1E6-8435-402A-B3C7-C84C558F162E-970-0000025C68CDC8D1_zps40398499
ultralite
Post by vw57drvr on Tue Mar 11, 2014 8:15 pm
If there is a vacuum port it should be near the mixture screw.
Post by ultralite on Tue Mar 11, 2014 8:32 pm
Thanks! Is the mixture screw on the left or right side of the carb?
ultralite
Post by vw57drvr on Tue Mar 11, 2014 8:48 pm
Should be on the same side as the idle stop screw. It's a thumb screw in the base of the carb.
