Is there a chart...
Is there a chart...
Is there a chart that shows where all the vacuum lines and hoses go? My bus is running good (knock on wood) but there seems to be a lot of unused things under the hood. And please don't go Samba on me and tell me that I should've read some post from 1994
Phatbizzi- Dub Noob
- Number of posts : 9
Registration date : 2014-02-12
Re: Is there a chart...
What year?
vw57drvr- Complete Dub Addict
- Number of posts : 902
Google it
^hahaha! Here is a good 1 for 71 and down... Pretty much all type 1 powered busses with a brake booster. It's not from 94, more like 09 lol... Google helped too lol lol
http://www.thesamba.com/vw/forum/viewtopic.php?t=384690
Attack chicken- Dub Nut
- Number of posts : 104
Ha, thanks. Seems like every time I ask a question on there I get told to search it. Can't a brotha be lazy? I have a 72 westie with a 2000cc in it. Fuel injection changed out to a single two barrel. The one I'm most concerned about is the black box that's clipped onto the top of the block. I think a hose used to go into the air filter from it at one time but the filter that's on there now doesn't have a place for it. A little bit of white steam/smoke comes out and evidently a spit of oil every now and then because it's kinda starting to build up on the shroud. Has anyone ever had this problem?
Phatbizzi- Dub Noob
Need to put a 1/2 inch hose on it and feed it to a breather box then back to the carb to pull crank case pressure. single two barrel you mean progressive carb they come with a plastic elbow fitting that goes in filter lower tray should help your problem.
Ok, I'll look for that tomorrow. Thanks 👍
Phatbizzi- Dub Noob
Now that I know it's called a breather box, I've found what I'm looking for. Now that I know what to search for
Phatbizzi- Dub Noob
