Newb cutting more teeth......
Post by swelchy on Tue Dec 03, 2013 5:00 am
I finally got around to trying to learn how to do my own valves. This past week while I had time, I am proud to say I did the job effectively and correctly. Cleaned my valve covers up inside & out. Used a tiny bit of brushable gasket tack on valve cover side of gasket. No RTV of course. I am glad I finally got the courage to do it because I had three valves that were way too tight. Got her all buttoned back up and checked the timing after she warmed up with a strobe.... Viola.... I swear it runs so much smoother now. I'm doing this every other oil change for sure.... it's too easy not too. I was scared I would screw sumthin' up and not be able to drive until I had a coach of some sorts.... This is my Daily Driver.
I've been piecing together parts to build another motor. I do have a bottom end already put together and I'm working on the heads now for a 1776......
swelchy
Number of posts : 66
Re: Newb cutting more teeth......
Post by vw57drvr on Tue Dec 03, 2013 8:28 am
You would be amazed how many people dont understand how to adjust their valves. Adjusting them on a routine basis allows your engine to tell you if it needs more attention.
Number of posts : 901
