Carb popping and skipping
Carb popping and skipping Empty Carb popping and skipping
Post by ridikas Fri Sep 27, 2013 4:24 pm
When I go to accelerate the carb pops and sometimes it has a delay in accerleration. The Carb is the dreaded pict 34 brand is one of those Chinese Junkers!
ridikas
ridikas
Number of posts : 377
Carb popping and skipping Empty Re: Carb popping and skipping
Post by Bugman114 Fri Sep 27, 2013 8:35 pm
Didju try cleaning the idle jet out? It's the brass thing on the right side of the carb. Many times U'll get a tiny bit of junk stuck in there.
Post by ridikas Fri Sep 27, 2013 8:59 pm
I'll check tomorrow
ridikas
ridikas
Post by ridikas Sat Oct 05, 2013 1:55 pm
When you take the idle jet out do you have to re adjust it?
ridikas
ridikas
Post by Bugman114 Sun Oct 06, 2013 9:55 am
Nope. There is no adjustment, just screw it back in. U did take the one out of the right side correct? The ones on the left are the mixture (small one) and idle (fat one) screws. If u took those out, they will have to be adjusted. IIRC its just a flat tip screwdriver to remove, but be careful to not touch the wire on top of the alternator as it is always hot and it will short out if touched by the shaft of the screw driver (learned that the hard way, XD)
Post by ridikas Sun Oct 06, 2013 7:48 pm
Rain is moving in here I'll try to get it tomorrow. Thanks for the tip about the alternator. That would have not been fun
ridikas
ridikas
