Narrowed Beam Tow Bar
+2
1SICGHIA
6 posters
What do you all use/do for a tow bar when you have a narrowed beam?
Pics?
Pics?
1SICGHIA- Dub Noob
- Number of posts : 20
Registration date : 2013-08-15
Re: Narrowed Beam Tow Bar
Lowboy trailer with a good winch. Would never use a tow bar on a narrowed beam vdub. Or a nice tow truck
Trailers are for boats.
Usually just narrow a tow bar To fit the beam
- Number of posts : 1416
Need a good drop hitch. I tow bar all the time. Only prob I have ever had is the towbar dragging a little
sploval53:
When you narrow the tow bar, where are you cutting it at? I did it once in the past, created some extra bracing for it and welded it up, but never felt to confident in it holding very well.
1SICGHIA- Dub Noob
I had to narrow my tow bar because of a baja bumper that bolted just inside of the shock mounts. I cut a section out of the cross bar in the center between the two arms and used a ratcheting tie strap to pull it together, the arms twisted a bit and the crossbar formed a peak because of the twist but it narrowed it enough to get it on. I'm not worried about it at all even with no extra bracing. Mine was like this. It is now narrowed to 22 1/2 inches1SICGHIA wrote:sploval53:
- Number of posts : 787
Cut in the center brace and also cut the two pieces from the hitch we sleeved where ever we cut and welded it back together
Thanks! That is definitely better than the way I did it as a kid. Now I need to find a tow bar to hack up.
1SICGHIA- Dub Noob
Kale has one for sale in the sale thread. Good as any other out there.1SICGHIA wrote:Thanks! That is definitely better than the way I did it as a kid. Now I need to find a tow bar to hack up.
ping349n- Dub Nut
- Number of posts : 344
Thanks for the heads up, just sent him a message about it.ping349n wrote:Kale has one for sale in the sale thread. Good as any other out there.1SICGHIA wrote:Thanks! That is definitely better than the way I did it as a kid. Now I need to find a tow bar to hack up.
1SICGHIA- Dub Noob
I bought the tow bar off Kale and narrowed it the other night just the way you suggested. Worked out great and took no time at all.pwmcguire wrote:I had to narrow my tow bar because of a baja bumper that bolted just inside of the shock mounts. I cut a section out of the cross bar in the center between the two arms and used a ratcheting tie strap to pull it together, the arms twisted a bit and the crossbar formed a peak because of the twist but it narrowed it enough to get it on. I'm not worried about it at all even with no extra bracing. Mine was like this. It is now narrowed to 22 1/2 inches1SICGHIA wrote:sploval53:
Thanks!
1SICGHIA- Dub Noob
» Narrowed BJ Bus Beam
» Narrowed Tow Bar
» Narrowed beams?
» ball joint beam
» I need a type 1 beam widened.
» Narrowed Tow Bar
» Narrowed beams?
» ball joint beam
