Smoking bug
Page 1 of 1 • Share •
Smoking bug
It was a treat to meet a few of you guys last weekend at say it loud, and to see your rides.
I drove my bug for the first time last weekend for about 3 miles and 20 minutes or so and it smoked when I turned it off. It seems to be coming from the drivers side around the manifold. There is also a smell. It does not smoke out of the tail pipes. What could it be? Any advice is greatly appreciated.
Thanks Chris
Thanks Chris
Cdub- Dub Noob
- Number of posts : 10
Registration date : 2013-08-24
Re: Smoking bug
It was good meeting you as well
Sounds like you probably have a leaking valve cover. If the gasket is bad it can leak right down on the exhaust and of course burn off. I would check that first
aircooledaddicts- Out of Control Dubber
- Number of posts : 1670
» WHYS MY KOHLER SMOKING?
» Jane and Arlene, "Smoking"
» Any reason for my carb to smoke from the choke side?
» Smoke N Mirrorz Stawell Top 20
» Is it possible that the starter won't work because of the heat off the engine?
