Not sure, but something is out of whack.
Not sure, but something is out of whack. Empty Not sure, but something is out of whack.
Post by Cdub on Wed Aug 28, 2013 2:02 pm
Hello, I am very new to Vw's and mechanics in general. I have a 1973 super beetle with a 1971 dual port 1600, standard single vacuum distributor and a 30 pict 2 carb.
That I was given as a trade. It was in pieces as far as wiring, I replaced the main loom all ignition components and rebuilt the carb.
It will barely idle and has little power when I drove it around the block.
Not sure what the issue is.
Any help would be greatly appreciated.
Cdub
Cdub
Number of posts : 10
Registration date : 2013-08-24
Not sure, but something is out of whack. Empty Re: Not sure, but something is out of whack.
Post by sploval53 on Wed Aug 28, 2013 2:06 pm
Check the firing order and make sure the vacuum line s not clogged up
Number of posts : 1416
Post by aircooledaddicts on Wed Aug 28, 2013 3:33 pm
A few things I would check are timing, valve adjustment, and points
Post by Cdub on Wed Aug 28, 2013 4:22 pm
I have checked the timing the static way and I put a straw in the #1 plug hole, I noticed it went around to TDC twice and my button is lined up with one. I set the valves to .006 and the points to .016. Could a faulty or clogged exhaust cause this?
For my distributor and carb single vacuum and 30 pict 2 where does the vacuum line go? I currently have it on the left side of the carb.
Cdub
Cdub
Post by Cdub on Wed Aug 28, 2013 4:29 pm
Sorry, thank you for such quick responses!
Cdub
Cdub
Post by Cdub on Wed Aug 28, 2013 9:53 pm
Is there anyone that lives near Sugar Hill that could help me troubleshoot?
Cdub
Cdub
Post by ASBug on Thu Aug 29, 2013 9:07 am
aircooledaddicts wrote:A few things I would check are timing, valve adjustment, and points
X2 in that order.
