Need help again... Points and condenser.
+11
ggaagg57
Gabass
ridikas
Brooks424
15 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Need help again... Points and condenser.
There is a wire behind the drivers side rear seat. If it is disconnected your car will not start. Sometimes they wiggle loose
ridikas- Dub Nut
- Number of posts : 377
There is no wire on early beetles, except for the battery cable. You said it almost fired. That is progress, so we know it is getting fire sometimes. I am going to go back through this post to see if I missed something. The center electrode didnt fall out of the distributor cap did it?
vw57drvr- Complete Dub Addict
- Number of posts : 902
My guess is that the new condenser is bad. I would put the old one back on and see what happens....
Can't help you with points and a condenser because I've never needed them in the 15 years I've been daily driving my cars.
So in case I missed something, why did you waste the time to comment? Just curious.
Brooks424- Dub Nut
- Number of posts : 157
Registration date : 2011-10-31
bumblebuggy wrote:Can't help you with points and a condenser because I've never needed them in the 15 years I've been daily driving my cars.
Brooks424 wrote:So in case I missed something, why did you waste the time to comment? Just curious.
hes telling you to get electronic ignition
Yeah, like Peter said, Glenn's not wasting time, he's a believer in electronic ignition units like the Pertronix. It's an alternative to using the points/condenser setup.
You put the unit in, set the timing once, and don't have to adjust it again. Only drawback is if they die, they die completely (no limping the car back home). I've only had one Pertronix die on me, and it was my fault cause I left the key on to long and fried it.
Oh. Well sorry. I missed that. I have no clue what that involves either ha! I know I couldn't manage that. How much are those $?
Brooks424- Dub Nut
Yeah, I would get an understanding of the points and how all of that works before moving to electronic. Reason being is if that pertronix goes bad, your backup is points and condenser.
Bug Me Vedio
You might consider buying this set of DVDs which is I believe a set of ten vedios. I bought #9 which covers wiring. You can some times find them on Fle-bay or I got his card when in Sieverville,Tnn. His phone # is 1 800 6620071. They cover about anything you would want to do to your Bug. Hope this helps. Regards, Jim ..slimjimBrooks424 wrote:Reset the timing? Oh hell, no one said anything about that. Now I know I'm screwed. Ha!
Fayetteville - not sure on that.
jim conner- Dub Nut
- Number of posts : 172
jim conner wrote:You might consider buying this set of DVDs which is I believe a set of ten vedios. I bought #9 which covers wiring. You can some times find them on Fle-bay or I got his card when in Sieverville,Tnn. His phone # is 1 800 6620071. They cover about anything you would want to do to your Bug. Hope this helps. Regards, Jim ..slimjimBrooks424 wrote:Reset the timing? Oh hell, no one said anything about that. Now I know I'm screwed. Ha!
Yeah, if you're referring to the Bug Me video sets, the one that would be most useful in this situation is the general maintenance one, (#1). This shows how to replace and adjust the points, replace the condensor, and set the timing.
Jon65- Complete Dub Addict
- Number of posts : 875
points are simple , this is not that hard . coils and points, they work or they don't , just take it to a shop and have it fixed or buy a cheap new oo9 from clyed and be done with it.
ggaagg57- Dub Nut
- Number of posts : 484
Yea. I've been using a Pertronix since the first day I started driving VWs. I've completely rebuilt 2 different cars and never adjusted points ever. People talk about having spare points and condenser. Guess what I have? A spare electronic dizzy. So if my Pertronix ever does fail (one in 15 years of true daily driving) I have a spare. You either love 'em or hate 'em. Yes they cost more than mechanical points but they are easy to install, they don't foul, they don't need adjusting, and they'll out last several sets of points if you don't try and static time them or leave your ignition on without the engine running.
I may have some time this weekend to come out and take a look at it. Give me a call and we'll go from there. I believe you have my number.
Likewise x2
im like glenn iv been runing pertronix since 95 an still going no hiccups or farts they are awsome garry has some i have installed by empi that also work great just set your timing an ride
Did you get this sorted out?
Page 2 of 2 • 1, 2
Page 2 of 2
