Bus buying tips
Bus buying tips
Hey I see there is a bus forsale where I live and I would like to know what to look for. I know the obvious rust on the floor pans, but is there anything else I should look for? Thanks
ridikas- Dub Nut
- Number of posts : 377
Re: Bus buying tips
Check for rust under the bus on the frame. You don't want none of this! (not my bus, just a pic from the samba)
Re: Bus buying tips
A little scared now!
ridikas- Dub Nut
Re: Bus buying tips
Nah, there not all like that. That's an extreme case. My rear crossmember is in pretty bad shape, but it looks like it's mostly from abuse (using it as a jack point, hitting curbs, running over hobos), rather than from rust.
Re: Bus buying tips
Haha! I'll keep the faith and hope this one is in good shape. It looks like it has a hole by the drivers side floor pan.
ridikas- Dub Nut
Re: Bus buying tips
Here is some pics of the bus. Do you know what year?
ridikas- Dub Nut
Re: Bus buying tips
Is 3000$ a good deal. It runs, new carb and front end has been rebuilt
ridikas- Dub Nut
Re: Bus buying tips
Hows the rust around the windshield? How solid is the battery tray? How are the brakes? Rear bumper? Is it a daily driver? I paid 1000 for the snow cone bus and then put around 2000 more in it buying seals,tires, brakes and all kinds of smalls plus I did all the work myself.....so with that said it looks like its a little on the high side
Re: Bus buying tips
I'll look and check this list of hotspots too see if its solid. The guy said he drove it around to haul stuff. For his lawn business.
ridikas- Dub Nut
Re: Bus buying tips
I don't like that rust around the jack points. The rear corner could use some por15 too.
Re: Bus buying tips
Battery tray has rust and hole. He has a piece of wood that the battery is resting on.
ridikas- Dub Nut
Re: Bus buying tips
Test drove it and shifts smoothly. Motor came out of a letter bus, it's a 1600 cc dual port.
ridikas- Dub Nut
Re: Bus buying tips
How much to offer for it?
ridikas- Dub Nut
