Mityvac brake bleeding
Mityvac brake bleeding Empty Mityvac brake bleeding
Post by ibjamn on Tue Apr 30, 2013 10:52 pm
So, this may be common knowledge for most, but I just found out via searching the web.
I was having issues with the Mityvac sucking air like crazy from pulling air through the threading and minimal fluid being drawn. After, the brakes were still soft.
But, unscrew the bleeder valve half way out, dab a little grease around the threads and tighten back down.
After doing this, I was able to pressurize only the one time at each wheel and flushed the whole system.
ibjamn
Number of posts : 134
Mityvac brake bleeding Empty Re: Mityvac brake bleeding
Post by ASBug on Wed May 01, 2013 8:17 am
Nice!
Post by DOODLE BUGG on Wed May 01, 2013 10:06 am
mighty vac is the best thing since sliced bread
Post by ASBug on Wed May 01, 2013 1:06 pm
^ True Dat!
I got mine at Harbor Freight, yep a real mighty vac at HF.
I could not believe it.
It was only like $5 more than their stuff.
Mityvac brake bleeding Empty Price of mityvacs at harbor
Post by jim conner on Sat May 18, 2013 11:10 am
ASBug wrote:^ True Dat!
What price are the Mityvacs at Harbor? Thank's Jim SlimJim
jim conner
jim conner
Number of posts : 172
Post by 57RTOval on Sat May 18, 2013 2:56 pm
Number of posts : 529
Post by DOODLE BUGG on Sat May 18, 2013 5:21 pm
I got the one u hook your air line to a n all I do is watch
Post by pwmcguire on Sat May 18, 2013 8:49 pm
DOODLE BUGG wrote:I got the one u hook your air line to a n all I do is watch
I got that one too, It's the best brakes I have ever had
Number of posts : 787
Post by 57RTOval on Sun May 19, 2013 1:30 pm
Like THIS ONE or did you also get the master cylinder attachment?
Post by pwmcguire on Sun May 19, 2013 1:44 pm
like this one http://www.harborfreight.com/brake-fluid-bleeder-92924.html
