Replacing Windshield Seal In Bus
Replacing Windshield Seal In Bus Empty Replacing Windshield Seal In Bus
Post by AirKewled on Sat Jan 31, 2009 1:19 pm
We have the seal for our bus, but need help putting it in. Can anyone recommend someone? We are replacing the old one with a new cali style, but there is rust under the front window ( the usual ), and we need to repair that also before putting in the new seal. We usually drive to NC for help with the VW's, as there is an awesome shop there called Sunset VW's. But thats a hell of a ride right now, so I figured we would ask around first!
AirKewled
AirKewled
Number of posts : 13
Registration date : 2009-01-28
Replacing Windshield Seal In Bus Empty Re: Replacing Windshield Seal In Bus
Post by Joe on Sat Jan 31, 2009 5:30 pm
If you want to make a ride to Augusta we can do it.
We just finished a bus that had bad rust holes around the windows.
Joe
Number of posts : 219
View user profile http://ATVW.COM
Post by AirKewled on Sat Jan 31, 2009 7:12 pm
That sounds like a really good plan. How much do you guys usually charge for repair work? We have a few other spots we would like to have fixed also before they get any worse.
AirKewled
AirKewled
Post by zabo on Sat Jan 31, 2009 7:30 pm
all the vw shops that were around when i was there are closed now.
saw this one online - might be worth chcking out
savannah tow
Post by AirKewled on Sat Jan 31, 2009 7:35 pm
Zabo, THANKS! I never knew there was anything close to us that worked on air cooled! I will be calling them on Monday to see what they charge. cheers
AirKewled
AirKewled
Post by billieco on Sat Jan 31, 2009 8:56 pm
We can help you also. Just Give me a call. 678/764/5096 Cell
Or the Shop # 770-888-4909
Stockornaut Restorations
billieco
billieco
Number of posts : 305
View user profile http://stockornaut.com
Post by petervalle on Sat Jan 31, 2009 10:24 pm
Zabo thanks for info too. I did not have any idea of VW shops around here.
petervalle
petervalle
Number of posts : 184
Post by Joe on Sun Feb 01, 2009 5:42 am
You can give me a call #706-799-5375.
If its not rusted to bad it will cost whatever you think it's worth and will fix while you watch.
Joe
Post by AirKewled on Sun Feb 01, 2009 9:26 am
If its possible, I can send you a few pics of the rust spots and you can let me know if you think its bad. I know its a common spot for it to happen on the buses.
AirKewled
AirKewled
Post by Joe on Sun Feb 01, 2009 7:42 pm
That will work if you can get some.
Joe
Post by AirKewled on Mon Feb 02, 2009 6:14 pm
Ok, here are some pics I snapped today.
The first is where my brother took it to be fixed and painted when he had it, and they guy just stuffed fiberglass in a hole, and freaking painted it. Unbelieveable how idiotic and low down some people can be. The problem did not show up until the pieces from the body started to flake and fall off. Next are two pictures of the window area. It is basically rusted out right below the seal, all the way across.
Replacing Windshield Seal In Bus 004
Replacing Windshield Seal In Bus 005
Replacing Windshield Seal In Bus 006
AirKewled
AirKewled
Post by Joe on Mon Feb 02, 2009 6:41 pm
Sent ya a pm.
Joe
